Clicking from starter - JeepForum.com
post #1 of 9 Old 07-09-2013, 01:07 AM Thread Starter
jramirez86
I have a 95 wrangler with a newly installed 90 wrangler 2.5L engine. After stopping coolant leaks etc I finally tried to start her up and the starter just clicks and doesn't turn over. Now I've read about the CPS being a possible issue and ill get to that BUT I currently have the starter from the 95 installed since it was newer. From what I could see it looks identical even tho oreilly has 2 different part #s. so no prob i can put the old one tomorrow. Here's the weird part, when I try to turn it over the clicking continues even after I take the key out of the ignition. I have to disengage the battery for it to stop. Any help?
jramirez86 is offline
post #2 of 9 Old 07-09-2013, 01:10 AM
DaemonForce
Sounds like the starter solenoid is stuck on stupid. When was the last time you replaced it?
DaemonForce is offline
post #3 of 9 Old 07-09-2013, 01:19 AM Thread Starter
jramirez86
I can't say I have the whole thing is only 4 months old. I've only had the jeep since March then I blew a piston thru the block. I'm new to the scene but after tracking down a 2.5 here on the island I jumped on the opportunity even tho it's from a 90. The solenoid is built into the starter on these correct? If so how could I unstick it from STUPID MODE [ON] ?
post #4 of 9 Old 07-09-2013, 04:22 AM
DaemonForce
Well aloha kakahiaka! (*・ω・)ノ
Oh God, that's right. These things are more consolidated on a 4cyl engine! You don't have that cute little 5 way device mounted next to your battery like some adorable Frankenstein experiment. I'm not even sure what the cable hooks into.
You've seen the typical cylindrical Ford starters that we use on our inline 6 engines and such. I think the solenoid on yours is a smaller cylindrical device mounted to the main body of the starter like some sort of tumor. I think I have one of these starters but it's been a few years since I've checked what all is there. I know mine is enclosed in the same protective shielding as the starter(which is probably the first problem with it). I'm willing to bet they can be swapped out so that you can avoid replacing entire starters but I don't see that going on when I check NAPA. All I see are complete starters. There shouldn't be any reason to go through that much trouble.
After looking around some more I found this thing. I can't believe I'm suggesting this but it looks like Chrysler might actually be able to help.
post #5 of 9 Old 07-09-2013, 01:15 PM Thread Starter
jramirez86
Aye bro howzit! Yeah the solenoid is built into the starter. Does anyone know if there's any difference in the starters on a 95 vs a 90? I'm clean up down stairs and make sure the teeth on the starter caught right today after work.
post #6 of 9 Old 07-09-2013, 05:09 PM
DaemonForce
When looking up ignition parts for a 90 Wrangler, a starter relay becomes available and I don't believe that's what you need. The solenoid is mounted on the body of the starter. If there's a junkyard around there where you can find similar looking starters you MIGHT be able to pull a solenoid from one but even I think that might be a little extreme. This is supposed to be a new starter and it shouldn't be giving problems this soon.
post #7 of 9 Old 07-09-2013, 06:55 PM Thread Starter
jramirez86
Ok am update. I installed the old starter and now i can try and crank it and it still doesn't turn over but now when I stop trying to crank it it actually stops so that's a good thing I suppose. I'm trying to get my hands on a code reader to see if its reading a bad CPS or tps but no luck so far
post #8 of 9 Old 07-09-2013, 07:01 PM
DaemonForce
The 2.5L is fuel injected? That's probably one main source of trouble if you're relying on sensors just to start the engine. It's worth checking.
post #9 of 9 Old 07-09-2013, 07:16 PM Thread Starter
jramirez86
I release some pressure from the manifold so it's getting fuel. I'm really tapped for ideas at this point
