clearance? 3.55's and aussie - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > clearance? 3.55's and aussie
Nitro Gear Packages Now Available at Rockridge 4wdJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFFThe ULTIMATE "Selectable" Locker System! Brough
Unread 10-22-2007, 10:53 AM   #1
Muddeprived
Am i gonna have to remove the carrier and ring gear to install this on 3.55's or will the cross shaft go right in without ring gear interferenc? I know 3.73's ain't doable cuz i had to remove the carrier on my tj.
If it don't, i'll either remove it (lengthly) or just shave off the tip of the ring gear just enough to slide it in.
2001 XJ Sport 4.5" RC LA
Custom snorkel
Detours/winch
Flux Capacitor Heat Machine
Muddeprived is offline   Reply With Quote Quick reply to this message
Unread 10-23-2007, 10:36 AM   #2
chutta
I don't think the gear gets even close to the mid point of the carrier for the shaft.
Just removing the whole thing wasn't very tough for me and allowed me to do all the work at a nice upright position, taking far more grief out of the relatively easy job than doing it all on the ground and going back and forth for tools.
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline   Reply With Quote Quick reply to this message
