Cleaning Up/Painting 8.8 Axle - JeepForum.com
post #1 of 8 Old 06-25-2013, 08:23 AM Thread Starter
JerseyDriver
I am picking up a Ford 8.8 axle from a late 90's Explorer. Pics look like some very minor surface rust, but I'll get to see it closer in person tomorrow.
I'd like to clean it up and paint it. Any suggestions? I'd like to clean it up and prepare the rust spots a little bit before covering it with paint, which I'm assuming Rustoleum would be fine for paint?
I'm a newb to this, so any help is appreciated... thanks.
JerseyDriver is offline
post #2 of 8 Old 06-25-2013, 02:08 PM
jokerchief462
Get some assorted wire wheel brushes for your drill. That will do quick work and run it down till it is shiny if at all possible. Good cleaning with a degreaser and wipe down with some laquer thinner then paint away.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 8 Old 06-25-2013, 05:21 PM Thread Starter
JerseyDriver
Good call with the drill attachments. I'll see what I can find.
Here is a pic...
post #4 of 8 Old 06-25-2013, 05:22 PM Thread Starter
JerseyDriver
Looks like the file is too large to upload.
post #5 of 8 Old 06-25-2013, 05:38 PM Thread Starter
JerseyDriver
post #6 of 8 Old 06-25-2013, 05:42 PM
CrawlingForward
http://northshorejeeps.forumotion.com/t100-axle-build
Here's a thread of my personal D30 build. Hopefully it should give you some good views of the guts, etc. and help you out with the process, even if it's for a different axle.
Also in my JF build, I documented the 8.8 a bit, starting about halfway in
http://www.jeepforum.com/forum/f22/m...l#post12749348
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #7 of 8 Old 06-26-2013, 05:59 AM Thread Starter
JerseyDriver
Great thread... Thanks for sharing!
post #8 of 8 Old 06-27-2013, 11:25 AM
rjbruzan
It will last longer if you prime it with Rust-Opium rusty metal primer first. That stuff sticks to everything.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
