CJ7 w/Howell Running rich and rough - Page 2 - JeepForum.com
post #16 of 22 Old 12-03-2012, 11:25 PM Thread Starter
fastener
1987 YJ Wrangler
Originally Posted by cruiser54 View Post
Vacuum is too low and is indicative of retarded ignition timing. The MAP is probably telling the ECU that the engine is under a load when it's not, so the ECU adds fuel. Are there any adjustments on the Howell?
Any vacuum leaks? Have you tried spraying throttle body cleaner arond the intake manifold to head to see if there's a leak there?
You are exactly right. The low vacuum is fooling the MAP and in turn the MAP has the ECU dumping fuel.
I borrowed a friends smoke machine and the motor is tight. Couldn't find any leaks anywhere. All vacuum hoses are new. My friend who I borrowed the smoke machine from has his own auto shop. He is going to come over tomorrow and see if he can find something. So far he is stumped with me just giving him info over the phone. I keep thinking I'm going to find something simple (or not) but so far nothing. I'm going to give Howell a call tomorrow too and bounce the info off them.
fastener is offline
post #17 of 22 Old 12-04-2012, 06:52 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
In the meantime, twist the distributor a bit more advance and see what the vacuum does.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #18 of 22 Old 12-05-2012, 08:12 PM Thread Starter
fastener
1987 YJ Wrangler
Finally got some free time again. Tried advancing the timing and the vacuum maxed out at 13". From 12* to about 18* the vacuum stayed at 13" above 18* the vacuum started dropping.
fastener is offline
post #19 of 22 Old 12-05-2012, 08:31 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Something is funky in the "timing" department.
post #20 of 22 Old 12-05-2012, 08:50 PM Thread Starter
fastener
1987 YJ Wrangler
Could this possibly be caused by a bad damper? I noticed some of the rubber bushing material in my damper is coming out.
fastener is offline
post #21 of 22 Old 12-05-2012, 09:21 PM
rjbruzan
Yes that will give a false timing reading.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #22 of 22 Old 12-06-2012, 05:33 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That's a real possibility. Perhaps the outer ring has rotated?
