Cj7 stall problems - JeepForum.com
post #1 of 1 Old 04-29-2012, 06:54 PM Thread Starter
Gervin
1980 CJ7
Cj7 stall problems
Having some problems with my 1980 cj7 2.5 with stalling under higher rpm. I thought it was fueling problems at first but I'm not forsure now. Replaced fuel pump and rebuilt the carb and it has helped it run better but still not perfect. It will idle fine but when you take it down the road and put it under higher rpm or a load it will start popping and stall. As long as I stay at low rpm it's fine. It has been running a couple seconds after you turn the key off I don't know if that's some indication of what's wrong. Any help will be a great help!
Gervin is offline
carburetor , iron duke , timing
wants to stall when making a turn sometimes. Danny0717 Engines & Drivetrain 0 10-24-2011 12:41 PM
'98 2.5L wants to stall in Idle dubv72 Engines & Drivetrain 3 05-31-2011 07:20 AM
89 XJ Wants to stall at stops My1989Jeep Engines & Drivetrain 0 04-06-2011 10:16 PM
stall on steep incline? brinoff General Jeep & Off-Road Equipment 7 07-28-2007 10:37 PM
uphill stall? mike mcgovern Engines & Drivetrain 2 02-12-2002 12:43 AM
