CJ7 HEI upgrade no spark - JeepForum.com
post #1 of 9 Old 03-16-2012, 06:19 PM Thread Starter
planb722
I just installed a GM HEI distributor in my 86 CJ7 258 and I can't get a spark. I had the stock electronic distributor in with no spark and figured it was a module issue. Had the module tested and it was bad. Tired of replacing modules with it and took it out to replace with what I thought was something more reliable, but I still don't have spark. I spliced the BAT wire from the solenoid and have 12v at the coil. Am I overlooking something??
planb722 is offline
post #2 of 9 Old 03-16-2012, 07:56 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You didn't hook the wire up to the tach terminal on the distributor did you?
cruiser54 is offline
post #3 of 9 Old 03-16-2012, 08:18 PM Thread Starter
planb722
No sir. Def. on the battery side.
planb722 is offline
post #4 of 9 Old 03-16-2012, 08:20 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That's a great upgrade and I've done it twice myself. It should fire right up. Where did you get the HEI dizzy?
post #5 of 9 Old 03-16-2012, 08:45 PM Thread Starter
planb722
Bought from Autozone. Ordered one for an 83 Chevy I6. reused my dist. gear
planb722 is offline
post #6 of 9 Old 03-16-2012, 10:54 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I always used the dizzy gear for an AMC V-8 on the Chevy HEI dizzys. .
post #7 of 9 Old 03-17-2012, 12:42 PM
jnicewan
Im not sure if the 6cyl dist gear works for that swap, like said above I always used the amc v8 gear. You might pull the dist cap and turn engine over to see if its spinning the rotor. That is a good swap though, it woke up my 83 when i still had the 4.2 in it.
jnicewan is offline
post #8 of 9 Old 03-17-2012, 02:23 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Im not 100% sure but is the distributor rotation the same on a 6 as an 8?
post #9 of 9 Old 03-17-2012, 06:21 PM Thread Starter
planb722
Yes the rotor is spinning while I try to crank it
planb722 is offline
distributor , hei , no spark , no start
No Spark! wrangin_myNeck Engines & Drivetrain 47 11-30-2011 11:07 AM
No Spark bluebeast78 Audio, CB & Ham Radios, GPS, & Electrical 1 07-29-2011 02:32 PM
Want to stealth upgrade my previous audio upgrade Peregrine777 Audio, CB & Ham Radios, GPS, & Electrical 17 12-30-2009 08:33 PM
HELP!! no spark blackhawk099 Audio, CB & Ham Radios, GPS, & Electrical 10 07-07-2009 07:19 PM
no spark... jfrdog Engines & Drivetrain 1 03-04-2008 02:56 PM
