-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   CJ7 HEI upgrade no spark (http://www.jeepforum.com/forum/f19/cj7-hei-upgrade-no-spark-1344019/)
planb722 03-16-2012 05:19 PM
I just installed a GM HEI distributor in my 86 CJ7 258 and I can't get a spark. I had the stock electronic distributor in with no spark and figured it was a module issue. Had the module tested and it was bad. Tired of replacing modules with it and took it out to replace with what I thought was something more reliable, but I still don't have spark. I spliced the BAT wire from the solenoid and have 12v at the coil. Am I overlooking something??
cruiser54 03-16-2012 06:56 PM
You didn't hook the wire up to the tach terminal on the distributor did you?
planb722 03-16-2012 07:18 PM
No sir. Def. on the battery side.
cruiser54 03-16-2012 07:20 PM
That's a great upgrade and I've done it twice myself. It should fire right up. Where did you get the HEI dizzy?
planb722 03-16-2012 07:45 PM
Bought from Autozone. Ordered one for an 83 Chevy I6. reused my dist. gear
cruiser54 03-16-2012 09:54 PM
I always used the dizzy gear for an AMC V-8 on the Chevy HEI dizzys. .
jnicewan 03-17-2012 11:42 AM
Im not sure if the 6cyl dist gear works for that swap, like said above I always used the amc v8 gear. You might pull the dist cap and turn engine over to see if its spinning the rotor. That is a good swap though, it woke up my 83 when i still had the 4.2 in it.
cruiser54 03-17-2012 01:23 PM
Im not 100% sure but is the distributor rotation the same on a 6 as an 8?
planb722 03-17-2012 05:21 PM
Yes the rotor is spinning while I try to crank it
The time now is 05:00 AM.
