CJ7 Coolant Leak Behind Fan Assembly - JeepForum.com
post #1 of 2 Old 04-26-2010, 01:13 PM Thread Starter
stanmc
Hello - After replacing my thermo. housing gasket, I now realize my coolant leak is coming from the water pump area. When I removed the belt from the fan, I noticed I can wiggle the entire fan assembly 1-2 inches, and when lifting up on it the flow of coolant is noticeably faster out of the front of the engine where the fan assembly enters the engine.
I know I am not undertaking this repair myself. I'm wondering if anyone has a guess as to how much this may cost me at the average shop.
Thanks!
stanmc is offline
post #2 of 2 Old 04-26-2010, 04:06 PM
TBailey
1983 CJ7
The last water pump I had replaced was about 350.00.However it is not hard to replace I have replaced several water pumps in most cases it can be done in about two hours.
TBailey is offline
cj7 , coolant , leak
Alternator replacement, coolant leak bluemobius Engines & Drivetrain 3 04-12-2009 10:49 AM
Coolant Leak Clarifications StokedXJ11 Engines & Drivetrain 4 01-24-2006 08:55 PM
coolant leak trojan man Engines & Drivetrain 5 08-25-2005 11:44 PM
Help! - 4.0L I-6 Coolant Leak Brian's 97 ZJ Engines & Drivetrain 9 07-01-2004 04:22 PM
Coolant Leak...HELP!!!! TJDUDE6 Engines & Drivetrain 1 11-10-2001 08:58 PM
