Cj7 automatic transmission help - JeepForum.com
post #1 of 2 Old 11-20-2013, 10:18 PM Thread Starter
obiswankenobi
Have an 84 cj7 with factory straight six engine and drive train. The automatic transmission will not go into any gear. Thoughts? Should I rebuild or replace? What should I put in there? I am running 4.56 gears on 35's. I want to be able to drive on the highway to trails. Thanks!
obiswankenobi is offline
post #2 of 2 Old 11-22-2013, 05:55 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sure the transfer case isn't in neutral?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
