CJ fuel injection - JeepForum.com
post #1 of 8 Old 06-13-2014, 02:50 PM Thread Starter
BlueCJ402
CJ fuel injection
I'm interested in swaping out my weber for a fuel injection. Does anyone have any recommendations on brands, brands available, war stories or anything I should be aware of?
I have a 84' CJ7 4.0.
Thank you.
BlueCJ402 is offline
post #2 of 8 Old 06-14-2014, 11:56 AM
jason280
Are you looking to simply do a TBI or Howell style fuel injection conversion, or drop in a 4.0 head with fuel injection? I considered running a 4.0L head on my 258, but ended up going with an entire replacement 4.0 out of a '93 Cherokee.
None
jason280 is offline
post #3 of 8 Old 06-14-2014, 05:11 PM Thread Starter
BlueCJ402
No head replacement, just a Howell tbi type, is there any other brands out there that you can think of?
post #4 of 8 Old 06-14-2014, 08:27 PM
BlueRubiconrich
a webber likes to run on road at 3.5 . and 1.5 offroad just add a fuel pressure regulator to the webber and you will love it . I did it and it works great.and cheap too.
I don't use a return line and I was pummping out 7PSI.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #5 of 8 Old 06-15-2014, 02:14 PM
Tollster
1980 CJ5
Where is the regulator mounted at on your CJ Blue?
I have a weber 38 DGES on my 80, 4.2, and have never really been able to dial it in, it seems to run rich, as I have always had a backfire through the exhaust when I let off the throttle, particularly on long downhills.
~Tol
Tollster is offline
post #6 of 8 Old 06-17-2014, 01:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
~Tol
Fuel pressure is super important.
A regulator can be located in the fuel supply line between the fuel pump and carb.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #7 of 8 Old 06-19-2014, 05:17 PM
BlueRubiconrich
sorry it took so long ,I run my reg right off the carb with just a small fitting
I was told that was best.
post #8 of 8 Old 06-19-2014, 05:28 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I've done that also. Works great.
Here's the rub on this whole deal. You need to adjust the FPR using a fuel pressure gauge. Do NOT trust the numbers on the regulator itself.
