-   Engines & Drivetrain (http://www.jeepforum.com/forum/f19/)
-   -   Cj dies sometimes (http://www.jeepforum.com/forum/f19/cj-dies-sometimes-1545451/)
jamesfd52 07-05-2013 08:31 PM
Cj dies sometimes
I'm new here and new to the jeep world. I bought a 1975 cj5. On the way home it died and backfired. I noticed it did not have a gas vent hose so I put one on. Then tonight while showing it off it died again. Fuel gauge is broke so I put 5 gallons on it. Any ideas out there?
DaemonForce 07-05-2013 08:54 PM
What carb does it have? Is it able to idle properly?
jamesfd52 07-05-2013 09:02 PM
Idles fine. After it sets for a minute it goes on. I will have to answer the carb question tomorrow. Sorry. It just shuts down.
DaemonForce 07-05-2013 09:57 PM
Is it able to start back up right away? If not that might be an ignition thing then. When is the last time you replaced the Ignition Control Module?
jamesfd52 07-06-2013 07:09 AM
Like I said. I bought the jeep yesterday. I'm not sure when things have been completely done
jamesfd52 07-06-2013 01:23 PM
It has the 258 in line 6 and a carter carb
DaemonForce 07-06-2013 04:21 PM
Ah, so this is a completely different thing to you then. It's a classic arrangement that probably hasn't been overhauled since it was built. There's a lot I can suggest but there's a lot more to check. It's too much work until the actual problem can be identified. Keep an eye on how the engine behaves. Pay close attention to the ignition system behavior. How it dies, if it starts hard or acts like it has a bad coil or sounds out of time...Things like that.
You also seem to have an issue with venting fuel. Did the new hose help at all? Does the tank require a vented gas cap?
jamesfd52 07-06-2013 04:28 PM
The vented hose issue helped with losing fuel on turns and take offs. It is vented cap. My father in law said it seems to be out of timing. Gonna put a light on it Monday. I would love to find a complete wiring diagram of the entire jeep and do that first. Is slack in steering common
jamesfd52 07-06-2013 05:03 PM
@daemonforce. I also just noticed 2 vacuum hoses missing from the carb. 1 sucks and 1 blows
DaemonForce 07-06-2013 07:23 PM
Are they just small vacuum ports? Seal them off with caps. If they're the big ones on the front of the carb you need to tee them together and then plumb that into the big open port on your charcoal canister. Some guys cap the big port on the rear of the carb, I just plumb it into my rear PCV.
jamesfd52 07-06-2013 07:26 PM
They are 2 small ones. One on left and one on right. I will plug them
DaemonForce 07-06-2013 07:28 PM
Probably a good idea. This engine will sputter and constantly hiss when there's a gigantic vacuum leak like that.
jamesfd52 07-07-2013 07:43 AM
2 Attachment(s)
Here is one of vacuum ports
Attachment 643765
DaemonForce 07-07-2013 09:37 AM
Yeah, cute little vacuum leaks that cause endless sputtering, hissing and intermittent death. I would cap them off and then check the engine timing. It's probably in the right spot but who knows? I'm not used to seeing that kind of mounting base though. That looks like the 232 intake. Is that a YF Carter? You have a single barrel carb on a 258? I've always been curious about how well that would run. A lot of people with the more common 2 barrel Carters still complain that it's not enough for this old engine. I'm still on the fence about that argument and they'll preach Motorcraft until the cows come home but I think there's a certain element of unique operation lost when going to that. I would say if you can keep that engine from sputtering and dying when it only has a single barrel carb, you're pretty good at something. O_o
cruiser54 07-07-2013 03:38 PM
The lower one goes to the distributor vacuum advance. Plug the upper one for now.
The time now is 01:35 PM.
Resources saved on this page: MySQL 0.96%
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
