Quantcast CJ-7 - Loss and Regain of Power - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > CJ-7 - Loss and Regain of Power
Old 08-15-2005, 03:56 PM   #1
Snickrz75
Hey guys...I hope you can help!
I have a 1984 CJ-7 with a 258. It has 155,000 miles on the original motor and it runs very strong...most the time. Lately it has been acting like it is dropping cyliders intermitently while driving, idleing, whenever it feels like it. I can drive all day and have no problems or I can have it happend every other light.
I have replaced the plugs, wires, cap, and rotor with no change in the situation. I though that the rotten exhaust might have been causing some sort of compression issue and it was replaced today. Same problem coming home. I figure it has to be an ignition problem, but I am at a loss now.
I bought it two weeks ago and the original owner is at a loss to (go figure) this is my second Jeep and the last one had a similar issue (which turned out to be the carb). Any help out there?
Matt
Snickrz75 is offline   Reply With Quote
Old 08-15-2005, 08:37 PM   #2
gosupes
Intermittent issues can be any number of things, but I would look at ignition first. Do a search for HEI conversion and get rid of the Duraspark module. In a nutshell, you take a HEI distributor from a 80's Chevy 6 cyl engine (find at a local u-pull yard), change the gear, replace the cap and install new wires, open the gap on the plugs slightly and you're good to go. Most people can have everything done for under $100. Then do a search for Nutter bypass. It will talk about disconnecting the metering pins from the back of the carb. There's a good chance doing this will cure the intermittent engine problems.
1986 CJ7, 4.2 w/4.0 head, TFI-HEI hybrid ignition, Clifford manifold w/Holley 390 w/cold air intake, OBA (in work), 150 amp alt., 4.5" lift, Woody CV shaft, 4.10 gears - lunchbox in front, Truetrac in the back, twin-sticked, blower upgrade for running topless, keepin' it simple.
gosupes is offline   Reply With Quote
Glock Forum
