Chevy 4.3 into a CJ5 - JeepForum.com
post #1 of 8 Old 11-03-2012, 11:11 AM Thread Starter
carlbirt
1957 CJ5
I am looking at putting a 4.3 v6 from a Chevy blazer into my cj5. To avoid some of the adapters I'm going to be putting in either a Muncie SM465 or a Muncie SM420 along with a NP205. By putting in the NP205 i can eventually run a doubler if at some point I decide that its needed.
Plan is to find a full blazer that still has a good motor in it for the swap so i can have everything that is needed. By this I mean the wiring harness, computer, rear axle, motor mounts?, and i am sure i will find a few more odds and ends.
Just want to know if someone here has done the same. Looking to see what it involves I know that there is a decent amount of work that is involved with an engine swap. Just looking to see what problems or issues others have run into.
Thank you
carlbirt is offline
post #2 of 8 Old 11-03-2012, 12:00 PM
1SASjeepster
Carl,
Check out NOVAK JEEP CONVERSIONS on the internet. They have a lot of useful information on most jeep conversions. I am sure they can help.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #3 of 8 Old 11-03-2012, 12:05 PM Thread Starter
carlbirt
1957 CJ5
Thank you. I will go take a look.
carlbirt is offline
post #4 of 8 Old 11-03-2012, 12:10 PM
will228
will228's Avatar
if you're going spend the money and time to go through a swap you might as well go with a V8 of some sort. I did a 5.2 swap and cant see a v6 being worth all that effort.my 2 cents
will228 is offline
post #5 of 8 Old 11-03-2012, 03:07 PM Thread Starter
carlbirt
1957 CJ5
Was thinking of doing a v8 but decided not to. For what I am going to be using it for don't need that much power. I also used to own a blazer and the 4.3 had more power then I ever used and was a tough little motor.
carlbirt is offline
post #6 of 8 Old 11-03-2012, 07:45 PM
1SASjeepster
Carl,
Check out my signature for information about my thread. I dropped a 4.3 in my 1992 YJ. It is "frame up" restoration but it has a lot of information that can help you. I posted a lot of photos and put a lot of information just so people like you can see what it is going to take and make an informed decision. It is missing in a lot of threads with conversions.
Take care,
post #7 of 8 Old 11-03-2012, 09:28 PM Thread Starter
carlbirt
1957 CJ5
Thank u I will differently take a look at that. I am in the same process that u were in but for the fact that mine is a cj. It should help me out a pot more then with just the motor.
Thank you again
carlbirt is offline
post #8 of 8 Old 08-05-2013, 08:20 PM
mdavi03
Late model V6 into CJ5
If you use a late model V6 with injection, using the late model computer and wiring harness, be aware of all the security interlocks.
I used a 2006 V6 with it's wiring, and had to reprogram the computer to bypass the ignition magnetic lock, and had to add a 2nd stage wiring to the ignition switch in my CJ. The computer apparently looks for two inputs at the same time.
mdavi03 is offline
