chevy 350 - JeepForum.com
post #1 of 5 Old 12-12-2007, 09:33 PM Thread Starter
jeepin1270
chevy 350
my friend has a chevy 350 just rebuilt only 2k on it now. it is pushin 350 hp to the wheels it comes with (trans and drive shaft). for 500 i will be selling the trans and driveshaft. he is selling it to me for 500 dollars. what kind of transmission do i need for it to run and how much and what else will i need. can u give me a estimate and is it worth it. my jeep is a 05 x series/automatic.
jeepin1270 is offline
post #2 of 5 Old 01-18-2008, 12:30 AM
brian674
See what trans he ran and use the same. . .Also think about an axle.
I'd say if you want a 350 Chevy, it's the more popular swapped motor and has great after market support for the swap.
'There is nothing more deceptive than an obvious fact.' Sherlock Holmes
brian674 is offline
post #3 of 5 Old 02-01-2008, 10:50 AM
kscott01
1983 CJ5
I'm not too sure about an 05 wrangler, but I did it in my 83 cj. You're gonna need engine mounts, exhaust, adapter bell housing, possibly new radiator for different hose locations (mine were on opposite sides), and all components to make the engine run. Research your tranny, it might be strong enough to handle it. I went through Summit Racing for all my engine needs, and 4 Wheel Hardware for adapter needs. They both have excellent tech departments for any questions.
kscott01 is offline
post #4 of 5 Old 02-01-2008, 05:12 PM
thebluebeast03
From all my research and my uncle doing same swap... your going to need a larger after market radiator to keep that beast of an engine cool. Depending on how much off-roading your going to do you might should get dana 60.... a good website for this conversion is http://www.novak-adapt.com
thebluebeast03 is offline
post #5 of 5 Old 02-01-2008, 08:42 PM
severous01
severous01's Avatar
run a 700r4 or allison trans. if you can find the allison....keep it even after the engine dies.
also...if my chevy 7.5" can handle 450hp out of an lt1 383, i'm sure a dana44 will be enough for the 350. i had 450tq and launched at 2800rpm and never had a problem with the rear...and the dana44 is almost an inch bigger ring gear.
also, if you get a 3 core stock replacement you should be fine with some electric fans.
severous01 is offline
chevy V8 yj35s Engines & Drivetrain 5 11-26-2008 11:05 AM
Chevy 350 fatterman Engines & Drivetrain 2 12-12-2006 08:24 PM
Chevy LS1 or LT1 Jeepin_XJ_101 Engines & Drivetrain 11 04-05-2005 10:27 AM
Chevy V-8 jeepthing2000 Engines & Drivetrain 5 06-04-2003 05:02 AM
chevy 350 in a cj7 80cj7 Engines & Drivetrain 1 01-16-2003 01:05 PM
