Checking Transmission Fluid??? - JeepForum.com
post #1 of 2 Old 10-07-2010, 05:51 PM Thread Starter
SoGaCommander
2008 XK Commander
Hello everybody, I'm new here and new to the Jeep family. We just bought a 2008 Jeep Commander two weeks ago for the wife. It has 23, 500 miles on it. Last weekend I service the Commander changing all of the fluids.
The transmission took 2 filters. The regular style trans filter that attaches to the valve body & a spin on filter. Both are located inside the transmission pan.
My questions is.....When checking the transmission fluid, the book says to have the Trans in park, the transmission Dip Stick says to idle in neutral.
Which is the correct way? Or does it really matter?
Also from doing some research I found that the trans should hold 5.5 quarts of AT+4. With the trans hot I've put 6.75 quarts and it's showing just below the bottom mark on hot...>>>>*HOT*.
Is there any input somebody can give me on this also.....Thanks
SoGaCommander is offline
post #2 of 2 Old 10-07-2010, 09:00 PM
wheelin
check the trans fluid level with engine running trans in neutral, be sure to set the e-brake
wheelin is offline
Old but low-mileage transmission fluid need changing? bstew417 Engines & Drivetrain 3 07-02-2010 10:18 PM
98 TJ Sahara-Want to change Transmission Fluid- What Tranny do I pajeep15 General Jeep & Off-Road Equipment 1 11-10-2009 10:34 AM
Mopar manual transmission fluid VikesTJman Engines & Drivetrain 1 04-01-2009 04:03 PM
transmission fluid replacing Cherokee98_4x4 Engines & Drivetrain 1 02-11-2009 09:13 PM
Transmission fluid on T-case skid UTWeezul Engines & Drivetrain 3 02-16-2006 12:39 AM
