check engine light stops engine trouble. - JeepForum.com
post #1 of 5 Old 04-09-2012, 09:24 PM Thread Starter
Damnit94
I have a 94 xj 4.0l, I love it, recently it started choking out on me, its random and it became more frequent, it'll slowly sputter down like its gonna die and then snap back to normal, why? After a little bit of this the check engine light kicks on and then no more problems. What should I do?
Damnit94 is offline
post #2 of 5 Old 04-10-2012, 02:18 PM
sctmcly0
Pull the code from the engine and go from there. It sounds like you have a bad sensor and the computer is running off of its memory instead of inputs
sctmcly0 is offline
post #3 of 5 Old 04-10-2012, 05:33 PM Thread Starter
Damnit94
Im getting mutliple codes, but they are all leading to the oxygen sensor, the problem is in Cali there are 4.
Damnit94 is offline
post #4 of 5 Old 04-10-2012, 07:12 PM
USAXJ
My 96 XJ did the same thing. I scanned the codes and it pointed at the O2 sensor. Replaced that and no more problems.
USAXJ is offline
post #5 of 5 Old 04-10-2012, 07:13 PM
USAXJ
Check the first one in line.
USAXJ is offline
