Check engine light issue - JeepForum.com
post #1 of 1 Old 10-06-2008, 08:58 AM Thread Starter
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
Been chasing this one for about a month. My wife's WJ keeps throwing teh following code:
P1491 Rad Fan Control Relay Circuit An open or shorted condition detected in the radiator fan control relay control circuit. This includes PWM solid state relays.
I replaced the origional relay about 3 months ago with an aftermarket one from Autozone after the OEM one quit. Since then I get this code intermittantly. Sometimes I can reset the comp and drive for days with no code; other times it comes on again immediately. The fan works as it should (ie it only runs when engine gets hot then shuts off again) and the engine temp is good. Not sure how I could have an open or shorted circuit in a solid state relay? Anyone else have issues with a replacement not from the dealer? Is this one of those "only an OEM will work" things?
I really would like to get rid of the constant engine light so it can do its job if something else goes wrong.
Whybu1 is offline
Check engine light haterasfever Engines & Drivetrain 4 07-08-2012 10:23 AM
check engine light on... Gas cap?? OffroadPrincess Engines & Drivetrain 4 02-07-2010 05:01 PM
I6 check engine light Chrisca Engines & Drivetrain 1 03-04-2005 06:28 PM
check engine light on 98 I-6 TXjeep97 Engines & Drivetrain 1 11-06-2004 09:25 AM
check engine light on..........????????? mat25542 Engines & Drivetrain 2 10-24-2004 10:19 AM
