Check engine light, HELP - JeepForum.com
post #1 of 4 Old 07-04-2013, 06:44 PM Thread Starter
Lpjackson
2005 FSJ Cherokee
I am new to this forum so I hope I'm in the right place. I have a 2005 Laredo and I have two codes coming up on the cel, one is p430 and the other is p0710. I have noticed lately it is losing power going up hills and sometimes jerks or shudders when accelerating. I can't afford to take it to the dealership to be fixed or checked out and I am a single woman and know absolutely nothing about engines. I know auto repair shops often take advantage of women because they know they know nothing about them and will go along with anything they say. I need some advice on where to start and what I should do. I live on the outskirts of Augusta, ga. Thanks in advance for your help.
Lpjackson is offline
post #2 of 4 Old 07-04-2013, 08:23 PM
222Doc
222Doc's Avatar
P0710 Transmission Fluid Temperature Sensor Circuit Malfunction.
p0430 Catalyst Efficiency Below Threshold (Bank 2)
222Doc is offline
post #3 of 4 Old 07-04-2013, 08:25 PM Thread Starter
Lpjackson
2005 FSJ Cherokee
Is the trans sensor expensive to replace? Thanks
post #4 of 4 Old 07-04-2013, 08:30 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
P0430; http://www.obd-codes.com/p0430
P0710; http://www.helpforcars.net/obd_codes/p0710_jeep.html
That gets you going inn the right direction.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
