Check Engine, Crank AND Cam position sensor codes - Page 2 - JeepForum.com
post #16 of 16 Old 06-02-2012, 10:23 PM Thread Starter
Ruffnek
Originally Posted by laybackman View Post
Since you installed the timing chain set improperly the crank and cam signal are not in sync according to your factory presets in the PCM.
The crank sensor looks for movement and sends a signal to the PCM when it does detect movement. If none is 'seen' you get no spark and no fuel.
I think the cam sensor only times the firing of the plugs. So you adjusted the distributer by swinging the rotor back to make it right or you rewird the plug wires to make it right. Now it runs just fine, BUT the cam and crank sensor signals are not sync'ed. That must be why it runs just fine but the CEL is on. The fix: a 1" piece of electrical tape over the CEL...
Could be, except I took the timing set out and replaced it properly :P Black tape would work, lol, but I never like those kinds of fixes. I think I'm gonna contact Comp Cams and see what they say.
Ruffnek is offline
cam position sensor , check engine light , crank position sensor
trouble after engine swap 3.7L. different crank position ring on crank nubby Engines & Drivetrain 1 06-13-2009 05:48 PM
Where is the Crankshaft Position Sensor??? ScottN3N Engines & Drivetrain 2 11-26-2008 10:35 PM
EGR position sensor? delta490 Engines & Drivetrain 0 05-14-2008 11:09 AM
Cam Position Sensor AZG23 Engines & Drivetrain 0 03-02-2006 10:46 AM
Flywheel/Driveplate/Flexplate and Crank Position Sensor jeeprad Engines & Drivetrain 2 11-29-2002 10:01 PM
