Cheap hei for small block dodge - JeepForum.com
post #1 of 1 Old 05-25-2012, 09:33 PM Thread Starter
badbird17x
badbird17x's Avatar
1994 ZJ
Just remembered a trick I discovered about 10 years ago that I thought you small block carb guys might like. The Chevy chevette had an hei distributer that has a base that is perfect for small block mopar, an it accepts all the v8 internals and cap. I took a chevette base and I can't remember if it was Buick, pontiac, or olds, but I measured and one of those had the correct length shaft. Assemble the bop shaft in the chevette base and it drops right in and you have a 1 wire bulletproof ignition system in a small block mopar.
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
