Changing Front Diff Ratio - JeepForum.com
post #1 of 4 Old 09-08-2012, 01:58 PM Thread Starter
Lindo77
Hi all,
I just swapped by blown front diff with one from a wrecker. It said 3.55 on it (stamped), but after realizing there was a problem, I did the wheel turn counting "thing" and discovered it is 3.73. Really would rather not try to find another front diff. Wondering what it would take to change the gears to 3.55? Is it a complete rebuild, or easier? Can a home mechanic do it, or should I take it in?
'99 Jeep Grand Cherokee Laredo
Thanks for your help.
Lindo77 is offline
post #2 of 4 Old 09-08-2012, 06:02 PM
BlueRubiconrich
No I would go shop only on that one.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 4 Old 09-09-2012, 12:36 AM
BleepinJeep
1988 XJ Cherokee
thats a pretty tough job to get it right. last time I checked a new ring and pinion were about $250 and labor isnt cheap on that either. It might be cheaper to find another axle.
Website -
- The Best Offroad Videos of Youtube with None of the Boring Stuff!
You Tube -
- Awesome Jeep Related How-To Videos in HD.
A wise man once told me, "I am going to give you some advice; you can take it or leave it, but keep in mind that it is worth exactly what you paid for it"
BleepinJeep is offline
post #4 of 4 Old 09-09-2012, 03:36 AM
ltrail
1984 XJ Cherokee
If the jeep has any modifications and or you wheel it I would swap the rear gears if anything. Nothing wrong with a little more gearing. Gears are a fairly time consuming and very particularly set up thing.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
ZJ Smokin Hot Front Diff and Hot Rear Diff biggered Engines & Drivetrain 6 10-23-2010 04:37 PM
Changing Gear Ratio from 3.07 to 4.10 on d35 Splug Engines & Drivetrain 3 12-31-2009 10:48 AM
Changing Diff fluid in D30/d35 and D30 pinion Seal Crunchakah Engines & Drivetrain 2 05-30-2009 01:58 PM
I am an idiot!!! Please help- Changing diff fluids MuDD OlllllllO Engines & Drivetrain 5 07-12-2007 07:18 PM
changing diff fluid Tri_X_Troll Engines & Drivetrain 2 12-16-2006 07:08 PM
