Changing DS from 1330 to 1310... not a conversion u-joint fix - JeepForum.com
post #1 of 1 Old 06-01-2012, 11:31 PM Thread Starter
dcope17
Short story, can I simply pull off the axle end of a DS which has the 1330 ujoint and the ID splines and slide on a matching spline with a 1310 u joint size or do the splines need to be matched like a ring and pinion set?
Long story.
So, I have a TJ Rubicon... came with 1330s all around. Custom suspension and when setting up, the 1330 on the front comes close to the upper CA. UCAs and LCAs adjustable so I dial it in within so much to get caster, and yoke/u-joint clearance when cycling the suspension.
I had a time where I did some hard braking and the tires were singing ( not locked up but some noise ) and no problems. I avoided everyone's bumpers and such.
since then I have added a winch and had to make another hard stop last night and the axle yoke contacted the UCA. The metal is blue so I'm sure it threw quite a show of sparks. I can possibly turn the yoke more of a round shape to gain a little clearance but I think I need more than just a little. so, like above, can I just use the end of a regular TJ DS with 1310 joints and simply slide it on my DS at the splines then re-balance? Or, do I need to have the spline end cut off and a new spline set ( od and id splines ) with a 1310 end welded on?
Thanks for the help...
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
14 bolt u joint issue (1310 to 1350) 488TJ Engines & Drivetrain 6 05-03-2010 07:05 PM
1310 or CTM u-joints? VanBCguy General Jeep & Off-Road Equipment 21 01-05-2010 06:06 AM
u joint conversion help PillowPants Engines & Drivetrain 1 09-11-2008 06:04 PM
1330 Ujoint CV driveshaft apexjeepinjoe Engines & Drivetrain 3 04-02-2008 11:20 AM
153x 1310 cv? 360wrangler Engines & Drivetrain 0 01-02-2007 06:59 PM
