Changed to Full Synthetic Oil and have a leak. - JeepForum.com
post #1 of 8 Old 07-28-2008, 12:40 PM Thread Starter
SpoiledRotten
SpoiledRotten's Avatar
I didn't do much research before changing my TJ to synthetic. I just read many posts that pointed out how great it was. Maybe I just read what I wanted to read, but.....
I don't know if it had anything to do with it, but I developed an oil leak or two. I got under it and noticed that it was coming from a couple of places. I tightened the valve cover and the oil pan since they were noticeably too loose to hold the oil in completely. The only place I notice oil now after running the Jeep is between just behind the plate of the transmission. Probably the RMS.
Now, for my question.... If I change back to conventional oil, would it more than likely slow the leak or eliminate it? Is there any problem changing back to conventional? I would think that if you can change from syn, you could change back w/out problems.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #2 of 8 Old 07-29-2008, 07:42 AM
Ridin' Around
Most likely you had the leak prior to the change and the Synthetic may have flushed some "crud" out letting it go ahead and leak. Regular oil will more than likely not fix your oil leak. Get the seal replaced and stick with the synthetic. Good luck.
BTW, you can switch back and forth everytime if you like it won't hurt a thing!
Ridin' Around is offline
post #3 of 8 Old 07-29-2008, 11:38 AM
gomes512
1994 ZJ
^ Yep good advice there.
I to had leaks when switching over the first time. Got 'em fixed. I switch back and forth between dino and syn every summer and winter. No ill effects.
gomes512 is offline
post #4 of 8 Old 07-31-2008, 08:11 AM Thread Starter
SpoiledRotten
Good news from you guys. Thanks. I really like the feel of the synth oil. Just seems like more power and a smoother running motor. I also put it in my wife's Mazda Millennia and it seems to have more power as well. Could be my imagination, but sure seems to be better. I didn't want to change back to the dinosaur blend.
post #5 of 8 Old 07-31-2008, 06:40 PM
superadd
Yep synth is the way to go and yes you feel more power for a reason.
We use royal purple in our race cars and with my own eyes I have seen dyno results and a mustang with a blown and stroked 4.6 put down 680 to the wheels with joe gibbs break in oil then drained it, filled with dino ran again and the same air temp and engine temp with about the same results.
Drained the dino put in full snyth (royal purple) stuck back on the dyno and pulled 687 several times
So I would fix the leak and keep the snyth going cost a little more but protects better and MORE POWER ( deep grunt) ohohh ohhhhhh
superadd is offline
post #6 of 8 Old 08-02-2008, 06:41 PM Thread Starter
SpoiledRotten
Good words of advice and proof. I'll keep running the full syn. I really like it.
post #7 of 8 Old 08-04-2008, 01:22 PM Thread Starter
SpoiledRotten
I went out on a limb slightly. I broke down and bought some of the oil leak stop. It states that it reconditions the seals and gaskets. It looks as thin as the synthetic oil I used, so I don't see how it would stop up anything. I don't see it as something with a "gel" consistence, that would actually be put in to plug a leak. I'll see what happens and report my findings. If it prolongs the RMS change out, I'll be happy.
post #8 of 8 Old 08-05-2008, 08:06 AM
Whybu1
Lets go Penguins!!!!
Whybu1's Avatar
So $7 a quart Royal Purple got him a 1% HP gain over cheap oil; for my Jeep that comes out to a whopping 1.5 HP increase if I see similar results. Not sure I find it worth the $ for that gain. Heck taking out the back seat would give me about the same weight/HP ratio gain as adding $50 worth of that oil. Just an observation and my thoughts.
Whybu1 is offline
Mag 1 Full Synthetic magnusrw Engines & Drivetrain 3 07-12-2013 01:34 PM
Changed relay, fuse, and resistor - NO FAN tutelo161 Audio, CB & Ham Radios, GPS, & Electrical 4 06-21-2009 07:52 AM
Changed from one premium air filter to another. jeepster93 General Jeep & Off-Road Equipment 6 07-02-2008 09:48 AM
So I changed to a different turbo for the Kits... Bryson Street Jeep Forum 0 10-31-2006 07:40 PM
Should I go full synthetic or part or regular oil with a 4.0L 103k miles? TheJeepMan Engines & Drivetrain 3 12-20-2003 02:10 PM
