catch can - JeepForum.com
post #1 of 8 Old 12-06-2012, 06:50 PM Thread Starter
BryceBrown
1987 XJ Cherokee
catch can
I am puting a catch can on my jeep but does it need to have some sort of breather hole I have an inline six its out of an 87 I have a little spectre filter inthe front of the valve cover but its still blowing out
BryceBrown is offline
post #2 of 8 Old 12-07-2012, 08:04 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Blowing out is common. That is why they put a PCV valve in there.
As far as the catch can. you will need a vent. It will need a piece of foam or other porous medium to try to get as much of the blowby as possible.
Personally, I never got why anybody would want to externally vent a crankcase. All it does is get a film of oil on everything.
jeepdaddy2000 is offline
post #3 of 8 Old 12-07-2012, 08:55 PM Thread Starter
BryceBrown
1987 XJ Cherokee
Back in 87 there is three different ports on thw valve cover the one in the rear closest to the fire wall is the pcv and its not even a true pcv its hose that goes to the manifold that's it the one in the middle is the oil filler cap and the one closest to the front end is a breather it waS manufactured that whay that year its a breather that goes to the back of the air box that's how it was made and you can't plug it you'll ruin the motor I'm not trying to make a breather its just for the blow by its a catch can people don't add them to the motor that's how they were made I was asking a question so don't post on my thread unless you know what you are saying
post #4 of 8 Old 12-07-2012, 08:55 PM Thread Starter
BryceBrown
1987 XJ Cherokee
And the catch can is to catch the can that's why its called a catch can
post #5 of 8 Old 12-07-2012, 11:24 PM Thread Starter
BryceBrown
1987 XJ Cherokee
Oil
post #6 of 8 Old 12-08-2012, 06:22 PM
jeepdaddy2000
1971 CJ5
The original hose was routed to the intake via the air cleaner. This is called a closed system.
Any time you break the closed system, you make it an open system.
You are correct, Jeep did indeed run a ccv system for a number of years on the 4.0. Sometimes in my hurry, I overlook the year.
There are a number of reasons for excessive blow by (the only real reason for a catch can), however, since you no longer value my input, I will keep them to myself.
Oh, by the way.....
This is a period .
This is a comma ,
This is a capitol letter A. It goes at the beginning of a sentence.
Spell check is highlighted by a red underline. simply click on it and it will give you some options for the word.
I'm sorry. I rankles me to be told to go pack sand by someone who can't pass fifth grade english, So I will pack up my thirty years of mechanical experience (including ten as a professional mechanic) and leave you to your silly little Monster can.
post #7 of 8 Old 12-08-2012, 06:55 PM Thread Starter
BryceBrown
1987 XJ Cherokee
Ok let's go in order for starters it is still staying a closed system hinse the catch can it is the same idea as that hose going into the air box that's why there is a breather off of it second I did not post this thread asking if it was dumb or nit to have a breather valve on my valve cover because that's how it was built I didn't care that you thought it was dumb but third I did not know that in order to be a qualified mechenic you had to be an english major to the forgot to say that at mechanics school and when I took my ase certification and finally I get the same story every day in my shop some guy that is 400 years old saying that us young guys don't know anything I'm sure you think carburetors were the greatest invention to I don't care that you are older than dirt and that you can a good grade on your spelling quiz when it comes down to it you obviously don't know
post #8 of 8 Old 12-08-2012, 07:04 PM Thread Starter
BryceBrown
1987 XJ Cherokee
But im/ not trying to sit here and argue I post on here to ask other jeep proffesionals so that I can further my knowledge there is always something to learn so if you have something that would work better or any ideas id like to. Know I'm sure you know a lot to
