Casting number help - JeepForum.com
post #1 of 7 Old 04-13-2012, 05:14 PM Thread Starter
tdorsey10
1981 CJ5
Casting number help
I have a 1981 Jeep cj 5. I went to replace the valve cover gasket and discovered that the holes do not line up. After further investigation it looks like this is not the original motor. I think it is a later model engine. a 4.2 liter straight 6 cyl. I found this casting number 509013 can anyone tell me info. on this engine? I need a new valve cover that will fit? help please I need to Ride!!
tdorsey10 is offline
post #2 of 7 Old 04-14-2012, 06:30 AM
Jami
1973 CJ6
What is the valve cover made of(the one on there)? If it is plastic the early YJs came with them. I believe they can only be replaced with another plastic cover.
73 CJ-6 in the works
Jami is offline
post #3 of 7 Old 04-14-2012, 11:54 AM
1986cj
You are missing a number. Should have 7 digits. Look for the date build code. Passenger side of the block behind the dist look for a flat pad, it will be stamped there. Report back with the numbers and the letter. 81 block casting # 3235444 but that is for a 81-85 and a 86 and a 87-89, but there are some differences in the blocks even with the came casting #.
1986cj is offline
post #4 of 7 Old 04-15-2012, 08:13 PM Thread Starter
tdorsey10
1981 CJ5
the one on there now is metal. 509013 is on the side of the motor below the valve cover, it has 86 on the other side near the top of the motor.
post #5 of 7 Old 04-15-2012, 08:15 PM Thread Starter
tdorsey10
1981 CJ5
this is the only number on that flat pad? it has 86 on the other side near the top? any ideas?
post #6 of 7 Old 04-16-2012, 12:08 AM
1986cj
Are you sure the second "O" is not a "C" ?
5= 1985
09=September
C= would mean it is a 258
13=13th day of the month
This is stamped in the flat pad. It is not a casting right?
1986cj is offline
post #7 of 7 Old 04-17-2012, 07:26 AM Thread Starter
tdorsey10
1981 CJ5
stamped correct, it could be ill take a better look. Thanks you may have solved the puzzel. ill let u know,
4.0L Block Casting Numbers Suprpwrs Engines & Drivetrain 5 01-24-2013 06:03 AM
T-18 & Dana 20 Casting # Links?? Captainak Engines & Drivetrain 1 03-31-2012 10:57 PM
need help with casting numbers jmrjr Engines & Drivetrain 1 07-05-2010 02:35 AM
Need help with engine block casting numbers jesserb Engines & Drivetrain 1 06-08-2010 12:21 AM
Casting #'s mde Engines & Drivetrain 1 03-26-2003 02:14 PM
