Caster and camber. How to adjust? - JeepForum.com
post #1 of 26 Old 08-31-2011, 10:25 AM Thread Starter
xrideordiex27
Hey I have a TJ with a d30 front axle that I recently swapped in and ever since then my caster and camber have been way off. I can't seem to figure out how to adjust it and neither does my friend who's good with cars so I figured you guys can help out. Thanks in advance
xrideordiex27 is offline
post #2 of 26 Old 08-31-2011, 10:57 AM
ajmorell
ajmorell's Avatar
Camber isn't adjustable from the factory. Caster is adjustable via the cam bolts on the lower control arms. The only way to adjust camber is with offset ball joints. If your camber is way off then either your current ball joints are completely trashed or your housing is bent somehow.
ajmorell is offline
post #3 of 26 Old 08-31-2011, 11:11 AM Thread Starter
xrideordiex27
Well I have negative camber with the tops of the tires closer than the bottoms. Ballpoints are fine. So this is not adjustable?
post #4 of 26 Old 08-31-2011, 11:26 AM
ajmorell
ajmorell's Avatar
No, not without the offset ball joints. Sounds like something is tweaked on your axle
ajmorell is offline
post #5 of 26 Old 08-31-2011, 11:44 AM
biffgnar
biffgnar's Avatar
By 03 hadn't the factory stopped putting in the cam bolts? Horseshoes still there on the brackets, but no longer bolts.
biffgnar is online now
post #6 of 26 Old 08-31-2011, 12:42 PM
ajmorell
ajmorell's Avatar
You might be right, I kinda just assumed that they kept using them. I would think they would implement some means of caster adjustment though.
ajmorell is offline
post #7 of 26 Old 08-31-2011, 12:58 PM
biffgnar
biffgnar's Avatar
I can tell you for sure that by 06 there was no means of caster adjustment on the factory setup.
post #8 of 26 Old 08-31-2011, 01:20 PM Thread Starter
xrideordiex27
Forgot to add the axle is off a 97 jeep TJ. I also can't use cam bolts with my clayon long arms because the can bolts aren't rounded it's flattened. I'll try the offset ball joints but one side does it more than the other so do they have more of an offset than the other? Sorry for all the questions I'm just kinda mad at myself for buying these axles I should have waited and found a better set
post #9 of 26 Old 09-01-2011, 07:23 AM
ajmorell
ajmorell's Avatar
I think you can buy them with certain amounts of offset, but I haven't looked in a while. As for the caster, if you have clayton's longarms then it's a simple length adjustment on the radius arms.
ajmorell is offline
post #10 of 26 Old 09-01-2011, 01:07 PM Thread Starter
xrideordiex27
ok, anyone know what offset i should get? or is it just a hit or miss thing? heres what it looks like:
post #11 of 26 Old 09-01-2011, 01:14 PM
mdm
Farm Wheeler
If that photo is legit, offset ball joints aren't going to help you.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #12 of 26 Old 09-01-2011, 01:23 PM
austin6137
1990 XJ Cherokee
Holy crap you can see the axle tube is bent dam. Its beat get another axle
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #13 of 26 Old 09-01-2011, 02:06 PM
ajmorell
ajmorell's Avatar
Wow, that thing is toast. You need another axle man, even if offset ball joints could cure the camber problem I'd be willing to bet that front end is going to eat through bearings like none other.
ajmorell is offline
post #14 of 26 Old 09-01-2011, 05:21 PM Thread Starter
xrideordiex27
I'm gonna try to see how to check if the axle is bent... And yes the picture is legit it's kinda bad.. I have a Dana 30 with 3.07's perfectly good but the gearing I have now is 3.73's and gearing labor is too much money for me to have the gears swapped over.. I'm on such a tight budget with this thing after I do my rear long arm I'm gonna be done for awhile (minus fixing the front end)
So with that being said any suggestions for me who's on a budget? If I had the money to blow I would regear my perfectly good d30 I have in my garage to a 4.10 o 4.56s and do the rear as well then have 2 good axles.
post #15 of 26 Old 09-03-2011, 12:49 AM
spyjeep0520
Well you have the gears now in your extremely f'ed axle just swap em withe the good if you have someone who can help wont be too too bad its just critical on your preload, lash, and gear tooth mesh only allows so much play
spyjeep0520 is offline
Camber problems after lift MunkMaster General Jeep & Off-Road Equipment 5 08-22-2011 10:35 PM
MBRP Off Camber Fabrications Line-X Bumpers MBRP General Jeep & Off-Road Equipment 3 07-13-2011 06:35 AM
Help needed. jeep Front end. camber problem wowsholva Engines & Drivetrain 0 06-27-2011 01:53 AM
Setting camber on front wheels? possumwalk Tires & Wheels 4 09-11-2008 05:39 AM
camber LOCKED UP General Jeep & Off-Road Equipment 4 08-25-2003 08:14 AM
