Carter BBD nuttered 258 need help - JeepForum.com
post #1 of 7 Old 04-19-2011, 06:35 PM Thread Starter
WHiTEBOi619
I have a nuttered Carter BBD carb on my 258 and it needs replacing. I was looking online for one and found one but it is without the electronic stepper motor. my question is will it fit and work good without problems? Mine was nuttered by the PO and i dont know a lot about carbs.
Any thing willing and over 18 :rtft:
Originally Posted by JoonHoss View Post
and other oft-repeated yet misinformed myths which are continually perpetuated.... my Jeep doesn't have leak...you don't have to pay taxes...I can find any G-spot...
WHiTEBOi619 is offline
post #2 of 7 Old 04-19-2011, 09:43 PM
mbcj7
1983 CJ7
Not 100% sure if this helps, but my 83 CJ had a non stepper carb on it when I got it. I ordered a rebuilt one with the stepper on it. Just dis the nutter last night and all is good.
I got the jeep from a very good friend who drove it a while non-buttered with a non-stepper carb. My gues would be that yes it will work fine
mbcj7 is offline
post #3 of 7 Old 04-19-2011, 10:15 PM
ninjakid
1987 YJ Wrangler
You ever think about getting a Weber or Motorcraft?
They are a lot better IMO.
ninjakid is offline
post #4 of 7 Old 04-20-2011, 12:01 AM Thread Starter
WHiTEBOi619
helps a little. My uncle owned it before me and he did the nutter but the carb is done for, he has rebuilt it 5 times and said it just needs a new one. i found one on ebay that i thought might work since i have the nutter but i wanted to ask on here to see what other people think or if anyone has tried.
yea but also cost more and this is my DD that has to pass smog in California. right now i have little money.
post #5 of 7 Old 04-20-2011, 07:06 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
What's the problem with the carb? Describe the issue. Is it an idle problem or driving problem?
cruiser54 is offline
post #6 of 7 Old 04-20-2011, 07:30 AM
mcmud
1983 CJ8
While the non-stepper BBD will fit and can perform very well it will most likely draw the attention of the smog agent, then if he notices the ignition has bypassed the computor.....
mcmud is offline
post #7 of 7 Old 07-19-2011, 05:36 PM Thread Starter
WHiTEBOi619
well its been rebuilt i think 4 or 5 times already by the PO. It has bad idle and low power. i just hate driving with it
258 inline 6 , carter carb , cj7 , electronically controlled , nutter bypass
carter yf help drew22 Engines & Drivetrain 4 01-03-2011 10:44 PM
carter bbd woes ranger88 Engines & Drivetrain 4 08-11-2010 07:37 PM
Carter BBD Rebuild Kit Eagle Kammback Engines & Drivetrain 0 11-30-2007 04:37 PM
Carter Iquois Engines & Drivetrain 1 02-08-2007 09:29 PM
carter card mpbspb Engines & Drivetrain 7 08-07-2002 08:32 PM
