Carter BBD no stepper - JeepForum.com
post #1 of 6 Old 03-17-2014, 09:29 AM Thread Starter
unrulycj
1983 CJ5
I have an '83 CJ-5 258 with Carter BBD that has the stepper. The PO did the nutter bypass and I added a Mallory dizzy. I'm pretty sure the FOMOCO box is no longer connected to anything, except providing me one hot wire to my Mallory. The stepper is not connected at all...connector cut by PO. Can I get this stepper carb to not be soooo rich? Or, can I buy a non-stepper Carter-type and adjust the mixture manually?
thanks.
unrulycj is offline
post #2 of 6 Old 03-17-2014, 08:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
There was a trick to setting them to a neutral position and then unplugging them. You're kinda beyond that. Yes, a non-stepper motor carb can be used. Webers work great bTW.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is online now
post #3 of 6 Old 03-18-2014, 09:30 AM Thread Starter
unrulycj
1983 CJ5
Thanks cruiser. I've seen a lot if chatter about Weber's being hard to maintain. I have an MG with dual SUs. They are always complained about...I rebuilt mine with the master kit, set them up with my desired needle and jet combo and balanced them. That was 2005 and I haven't touched them since.
Now, that was all said to ask, which of the complaints are valid and which can be chocked up to lacking skill or laziness?
unrulycj is offline
post #4 of 6 Old 03-18-2014, 04:34 PM
carnuck
1984 J-Series Truck
The other option is to take the stepper off the carb and adjust it. Once it's unplugged, it's pretty much taken out of the loop. If someone near you has one with the same BBD compucarb, you can unplug their stepper and plug it into yours, then turn the key just to on, ground the stepper body (it will spin to center itself. Don't be scared when it moves)
Usually that is not the problem with over-fueling. The line coming in is bent in such a way that the weight of the fuel filter actually unscrews the seat, which raises the float level.
Photo borrowed from a Mopar site shows the seat leaking. The body through screws come loose too and adversely affect fuel economy and running. Metering rods in the top front can be adjusted lower for better economy (if out of adjustment)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #5 of 6 Old 03-18-2014, 09:20 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
As a multiple carb guy myself, I would not hesitate to do a Weber down draft conversion were I in your shoes. I've done a "synchronous" Weber conversion on a 258 with excellent results. Companies like Redline have kits with pre-jetted carbs so there's no issue there.
post #6 of 6 Old 03-18-2014, 09:22 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I have to ask.
Where do you come up with this crap? Has little or nothing to do with helping the OP but somehow satisfies your need to spin yarns about stuff that is useless.
