Carburetor Question - JeepForum.com
post #1 of 4 Old 07-24-2005, 02:48 PM Thread Starter
merch_boy
Carburetor Question
I currently have a Holley 4BBl carb that keeps getting the timing out of whack. I have had it with this carb and I am looking for a new carb. How much power will I lose if I go to a 4BBL carb? The Jeep has an Offenhauser dual port header. If I go to a 2BBL carb, do I have to change this as well? Many thanks!
merch_boy
83 CJ7
merch_boy is offline
post #2 of 4 Old 07-24-2005, 09:16 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
A carb will not effect your static timing. While you didn't tell us what engine,carb,or dist your running, the only thing the "carb" can effect is the vacuum advance. If your having timing issues, I'd look at the dist or timing chain, or a possable computer problem, if it is still equiped with one.
jeepdaddy2000 is offline
post #3 of 4 Old 07-24-2005, 11:46 PM
ScotZ
American to the Bone
ScotZ's Avatar
X2 Carb mixes fuel and air and delivers the mixture through the intake manifold. Possible vacuum leak somewhere. What kind of distributor are you running? A little more information please. Thanks Scot
At least two-thirds of our miseries spring from human stupidity, human malice and those great motivators and justifiers of malice and stupidity: idealism, dogmatism and proselytizing zeal on behalf of religous or political ideas.
- Aldous Huxley
ScotZ is offline
post #4 of 4 Old 07-25-2005, 12:04 AM
Traveller
Some Holleys have a spark vacuum port that is supposed to supply vacuum at higher than idle speeds. As hard as it is to get the mixture properly set on some Holley carbs I wouldn't be surprised if the spark vacuum port (if it has one) isn't working properly.
The old Offy dual port manifolds work best with a 4bbl carb. A 2bbl carb will still work, but a good 2bbl carb doesn't really cost more or less than a good 4bbl carb, so if you want to use the Offy, find another 4bbl.
Traveller is offline
Carburetor question Rathburn Street Jeep Forum 0 10-22-2008 04:40 PM
edelbrock carburetor question jeepcj304 Engines & Drivetrain 5 11-28-2006 11:03 AM
Carburetor 101, help me out please... 4x4 XJ Engines & Drivetrain 2 02-20-2003 06:28 AM
Carburetor Question CJ7Jeff Engines & Drivetrain 5 02-19-2003 06:39 PM
stupid carburetor question evilpsych Engines & Drivetrain 5 12-11-2002 12:48 AM
