can you have two different gear ratios? - JeepForum.com
post #1 of 14 Old 04-08-2009, 05:00 PM Thread Starter
corbin9191
I have heard from people that you have to have the same gear ratio in the front as you do in the back axle. Is this true or can you have different gear ratios from front to back? I just want to be make sure that what I am hearing is true. Thank you
corbin9191 is offline
post #2 of 14 Old 04-08-2009, 05:02 PM
oteps
1980 CJ5
Yes you need the same ratio front and rear. If not, while in 4X4 something will break.
oteps is offline
post #3 of 14 Old 04-08-2009, 05:05 PM Thread Starter
corbin9191
OK! that was all I needed Thank you
post #4 of 14 Old 04-08-2009, 05:31 PM
YeepieJeepie
It can be close though. 3.50 on one end and 3.55 on the other or 4.10 and 4.11 are acceptable.
I do know for a fact that 3.08 on the front and 3.50 in the rear will lead to a broken transfer case. Luckily transfer cases are really easy to rebuild on your workbench.
YeepieJeepie is offline
post #5 of 14 Old 04-08-2009, 08:23 PM
badoosh27
badoosh27's Avatar
you can have them, just dont put it in 4WD. i have 3.07's in the front and 3.73's in the rear and it works just fine in 2WD
2001 Wrangler Sport 4.0, 5 speed, 30/35 axles, 3.73's, ZJ springs, 1"BB, 31" Futura M/Ts
badoosh27 is offline
post #6 of 14 Old 04-08-2009, 10:04 PM
shrewd
I was reading an article today in one of the mags that said 1-2% difference was doable, as the extra stress it created was relatively minimal.
My D35 grenaded at 65mph, fun times.
shrewd is offline
post #7 of 14 Old 04-09-2009, 11:35 AM
jdarg
There often is a slight difference actually...the front axle and rear axle may not have the same number of pinion/ring gear teeth but the ratio works out to be within a few hundreths, i.e. 4.10 and 4.11.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #8 of 14 Old 04-09-2009, 01:17 PM
scout80xj
In 4 wheel drive on a highly tractive surface like DRY pavement (which has a high coefficent of friction) than you need the ratios front and rear to be within 2% (at the most) of each other. For example many factory trucks with the Dana 44 front/Dana 60 rear had 4.09's in front, and 4.10's in the rear in this is acceptable because they are within 2%. However...on a slippery surface with a low coefficent of friction such as Ice and mud you CAN get away with running two different ratios front/rear. But I would advise you to run ratios front/rear that are within 2% of each other If you drive in 4x4 alot.
scout80xj is offline
post #9 of 14 Old 04-21-2012, 10:16 AM
grandfan94
what if u run different tire sizes?
grandfan94 is offline
post #10 of 14 Old 04-21-2012, 01:41 PM
chainz
1976 CJ5
than you have some math to do....lol
chainz is offline
post #11 of 14 Old 04-21-2012, 02:36 PM
halpeters
1978 CJ7
This would be the only way....
Some of the racing 4x4 trucks do this to run different size tires front and rear.
Also, 4 wheel drive tractors with small wheels in the front, and large wheels in the rear do this...
1978 CJ-7
halpeters is offline
post #12 of 14 Old 04-22-2012, 06:44 AM
grandfan94
so would there be some fancy mathy way to find out the tire sizes, or just a simple sh-t cross-multiply?
post #13 of 14 Old 05-27-2014, 04:01 PM
Thrasymachus
Anyone know what the symptoms would be if there were different gear ratio's? My rear diff blew up so I had a locker and 4.56's installed. Also bought a TJ D30 with open diff and 4.56's. I swear that I recalled looking on the ring gear and saw "4.56" stamped/etched. When I let off the gas in 4wd (in neutral, with the clutch in) it has a noticeable deceleration/braking sensation... and I think the body is squatting. When I try to rationalize this if the front has a higher gear set, the front would try to pull away from the rear causing the body to squat. Vise versa if the front had a lower gear set the rear axle would be pushing into it and cause the body height to rise. This issue goes away when it is out of 4wd. I think I have already answered my own question... Just want others two cents?
Thrasymachus is offline
post #14 of 14 Old 05-27-2014, 04:23 PM
biffgnar
biffgnar's Avatar
It's not going to be subtle if you have a mismatch. If you are debating nuances you don't have a mismatch.
Romney in 2020!
biffgnar is offline
a question about gear ratios MC_NickP Engines & Drivetrain 1 01-19-2010 08:13 AM
Pinion gear ratios? Bulldog1 Engines & Drivetrain 1 02-25-2007 05:05 PM
what gear ratios? help halftank General Jeep & Off-Road Equipment 6 12-03-2006 10:40 AM
Gear Ratios?! GrrReece General Jeep & Off-Road Equipment 13 03-08-2005 11:26 AM
Gear ratios JeepN2 General Jeep & Off-Road Equipment 5 07-19-2003 11:26 PM
