Can't make up my mind - JeepForum.com
post #1 of 5 Old 02-22-2003, 12:51 PM Thread Starter
TDanks76
1979 CJ7
Okay My four banger has a couple knocks in it and the tranny is going. i was able to talk my parents into letting me have the 350 out of their surburban. Now I have a tired jeep and a 350 efi motor in the garage. i can't decide weather to drop the engine into the jeep or just to sell all the stuff and buy a new six cylinder jeep.
If i did the V8 Swap which would be cheaper to get? An Auto or manual tranny? also what kind of transfer case should i get? Then there is the rear axel part. could I last a little bit with the D35 until I got enough money to get a D44 or a ford 8.8?
if anyone has a write up or parts list that would be awesome.
Sorry, I did a search but I guess i wanted info from my own thread, and you jeep master.
CJ 7, with the good stuff.
TDanks76 is offline
post #2 of 5 Old 02-24-2003, 11:55 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Easy route?
350 with AX15 (you have the AX5 in your 4-banger) with a 23-spline NP231.. a 3-core radiator and AdvanceAdapter's 350 engine bolt-on motor-mounts.
Later on, flip in a Ford 8.8" rear end with disk-brakes from an Explorer (and I just heard that some Ranger's also use the same axle) - match the Ford's gear to your front axles 4.10 ratio (Explorers with the tiny engine have 4.10's) and call it done.
Price would be time, radiator, adapter for tranny - swap tranny and t-case for the one you want (maybe some cash would need to change hands), the motor mounts and some wires and hoses.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #3 of 5 Old 02-24-2003, 01:55 PM Thread Starter
TDanks76
1979 CJ7
This is what I planned out so far. Ford 8.8 for the rear, and a 700r4 automatic trans mission for the chevy 350. now what kind of transfer case can I use? I think I need a Ford Np205? and suggestion? remember driver side out put for the front axle.
TDanks76 is offline
post #4 of 5 Old 02-25-2003, 10:21 AM
NaeKid
NaeKid's Avatar
Advance adapters has one to go from the 700r4 to NP231 - both 21 spline and 23 spline input-shafts (you have the 21).
The NP231 is strong enough stock to run behind the 350ci engine with few problems.
Silver
NaeKid is offline
post #5 of 5 Old 02-25-2003, 03:36 PM Thread Starter
TDanks76
1979 CJ7
Few problems? Does that mean that if I'm standing my rig up on the rear axles and really driving the heck out of it I should look into something else? Will the Np 231 (21 Spline) be okay for things like sand and a little mud? I'm mostly in the sand.
TDanks76 is offline
Mind boggling back-fire. need help! BigDumbBear Engines & Drivetrain 9 11-10-2009 09:32 AM
Rolled on paint, don't mind the orange peel but don't want the streaks. Brandon_YJ General Jeep & Off-Road Equipment 1 05-10-2008 07:13 PM
help! alarm has a mind of its own 97tjtom Audio, CB & Ham Radios, GPS, & Electrical 6 01-02-2008 11:24 AM
cd player w/ mind of its own bananamane Audio, CB & Ham Radios, GPS, & Electrical 4 10-13-2005 11:13 PM
need help making up my mind JeTravep Tires & Wheels 1 05-12-2003 03:24 PM
