can't get into 2nd 4th 6th or reverse - JeepForum.com
post #1 of 4 Old 11-21-2012, 05:24 AM Thread Starter
05peejunlimited
I just completed a 4inch lift on.my 05 unlimited. I knew 2nd might be an issue and may need the floor board trimmed. But all my down gears? Has anyone had this issue....
05peejunlimited is offline
post #2 of 4 Old 11-22-2012, 05:49 PM
Tomsjeep2
I had this same problem with my black diamond 3 inch lift. im not sure what the proper remedy is but what I did with mine was I unbolted the shifter from the tranny then cut the lower part of the shifter and welded it to where you can shift into those gears. Worked for the past 3 years with no problems. Hope this helps
Tomsjeep2 is offline
post #3 of 4 Old 11-23-2012, 07:53 AM
Jason
That 4-inch lift must have come with a t-case drop too. I had the same issue with mine in all the lower gears on the pattern. In my case, it was interfering with the plastic console. You can unbolt it, move it an inch or so back and drill new mounting holes or trim the console where it's interfering. I heated and bent my shifter to make it clear.
Jason is offline
post #4 of 4 Old 11-23-2012, 09:58 AM
Pete3
You just need to check everything the down shift comes in contact with and do some trimming.
Pete3 is offline
