cam questions - JeepForum.com
post #1 of 5 Old 06-18-2014, 10:48 AM Thread Starter
coolbreeze48
cam questions
hi, 2003 jeep grand cherokee laredo 4.0i6
my jeep has the infamous lifter tick
so i removed the head to check, pulled all lifters,
and checked them, they all looked good with even wear and no cupping or scoring, so i proceeded to use a dial indicator for my camshaft to check lift.
i checke it while lifters and pushrod was in .
these are my findings .. highest reading was .250 and lowest was .241
now i think i found stock specs wich are
Camshaft Lobe Lift
Exhaust: 6.579 mm - (0.259 in.)
Intake: 6.477 mm - (0.255 in.)
is this cam any good,??
coolbreeze48 is offline
post #2 of 5 Old 06-18-2014, 01:30 PM
BIGBADWOLF
did you remove tension from the rockers? Hydraulic lifters are not solid with engine off and the plunger spring will give a little.
BIGBADWOLF is offline
post #3 of 5 Old 06-18-2014, 05:26 PM Thread Starter
coolbreeze48
yes , pulled head took reading directly off of lifter, even pulled lifters to see if plunger would go down ,it didnt so got good reading
post #4 of 5 Old 06-19-2014, 09:43 AM
BIGBADWOLF
Usually .001 is max for lobe wear. How accurate is your measuring? Are you using a dial indicator?
post #5 of 5 Old 06-20-2014, 06:04 PM Thread Starter
coolbreeze48
yea, i used a good dial indicator, the worse one was .013 out,
surprisingly the damb thing wasnt missing, just a mild lifter tick is all
hell being that far out the thing should have been missing
