Bump throttle?! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Bump throttle?!
Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri2007-2016 Jeep JKU 4" X-series suspension lift **dea
Unread 04-16-2012, 09:07 AM   #1
reaxion911
Bump throttle?!
To start 2000 tj 2.5 w 4.0 tb on 31s. The only way i can explain this is after i installed my 4" lift i have this issue where it sounds like the jeep is bumping off of the engines power or bouncing off of it if you will. Its really bad in the the slow bumpy stuff especially after installing the tb and lubing the cable as my peddle is very touchy. Ive put a hand throttle in the make it easier to contend with but i think its time to address the problem. My first thought is that my motor mounts cold be worn out? Next would be that i only replace the lower con arms with my lift and im thinking the upper con arm bushings are worn out causing wrap causing this whole bounce thing. Any thoughts guys! Any help or suggestions would be greatly appreciated. Oh and i know owning a 4 cyl to jeepers is like owning a sportster to bikers but please dont bash its my bad choice and i know i have to live with it.
reaxion911 is offline   Reply With Quote Quick reply to this message
