Broken Dana 30 JK - JeepForum.com
post #1 of 4 Old 07-05-2012, 01:53 PM Thread Starter
moe10
Broken Dana 30 JK
If I take the axles out and disconnect the front driveshaft, can I still drive without damaging anything else until I get a new axle?
moe10 is offline
post #2 of 4 Old 07-05-2012, 02:18 PM
KingtheZJ
yes as long as you keep the stub shafts in the unit bearings.
what is wrong with it?
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 4 Old 07-05-2012, 03:35 PM Thread Starter
moe10
I snapped the right front at the U-joint.
moe10 is offline
post #4 of 4 Old 07-05-2012, 03:41 PM
KingtheZJ
just take out the inner shaft and youre good. if you want the front end to not spin, pull the other side inner shaft
'88 XJ
dana 44 lsd retaining clips broken - what to do? jeepfreaks Engines & Drivetrain 0 02-22-2010 07:35 AM
Dana 35 broken spider gears MUDDS_UT Engines & Drivetrain 7 12-08-2009 04:26 AM
DANA 30 outers on DANA 44 front axle-- with a twist IN8LYJP Engines & Drivetrain 1 07-08-2009 05:40 AM
Dana 60 axles in Dana 44 housing external hubs dustydoggy Engines & Drivetrain 1 03-26-2009 01:39 AM
Bolt in Dana 44 or Dana 60 Rear Assy - Looking for a dealer wheelinjames Engines & Drivetrain 18 09-23-2006 07:02 PM
