Broken Bolt removal procedure - JeepForum.com
post #1 of 11 Old 03-01-2012, 04:01 PM Thread Starter
AMCMasterTech
In an effort to be less of a lurker/leecher, and more of a seeder/giver/contributor, I've been photo-documenting both diesel TJ builds. Even the most mundane stuff can be interesting, so here goes.
This 2011 CJAA diesel was removed from a new Golf that had sustained a head-on collision. In the process of being crashed, the oil filter/cooler housing was broken-off, with several bolts sheared flush with the engine block.
"Hit em' where they ain't"
Roy D. Chapin Jr.
AMCMasterTech is offline
post #2 of 11 Old 03-01-2012, 04:02 PM Thread Starter
AMCMasterTech
I used Blue Point kit 1020 for the drill and tap. The set is rather old-school but works great and saves time. This one has come in handy several times.
Roy D. Chapin Jr.
post #3 of 11 Old 03-01-2012, 04:05 PM Thread Starter
AMCMasterTech
First, I cleaned the area od loose dirt and placed some cleaning cloths in the oil gallery openings.
Roy D. Chapin Jr.
post #4 of 11 Old 03-01-2012, 04:44 PM Thread Starter
AMCMasterTech
Using a center punch, I tagged both bolt shanks as close to center as possible. NOTE: theres a few things "going cheap" will not work - punches/chisels/drifts are worth going expensive with.
Roy D. Chapin Jr.
post #5 of 11 Old 03-01-2012, 04:48 PM Thread Starter
AMCMasterTech
I used the extractor kit drill bit, cordless drill on low speed, and plenty of spray lube as cutting fluid. 125 RPM was plenty fast.
Roy D. Chapin Jr.
post #6 of 11 Old 03-01-2012, 04:50 PM Thread Starter
AMCMasterTech
I then placed the extractor in the drilled hole and tapped gently with a hammer to seat. The hex coupler slid over the extractor.
Roy D. Chapin Jr.
post #7 of 11 Old 03-01-2012, 04:53 PM Thread Starter
AMCMasterTech
Both bolts had thread locker on them, which made for some resistance. But with a little patience, both bolts backed right out.
Roy D. Chapin Jr.
post #8 of 11 Old 03-01-2012, 04:56 PM Thread Starter
AMCMasterTech
I then washed the area gently with carb cleaner, and padded dry. I used a magnet and cloth to get any remaining metal shavings. I used tape to cover the boss until the new part comes in.
IMG00935-20120301-1335.jpg   IMG00939-20120301-1343.jpg   IMG00940-20120301-1404.jpg
Roy D. Chapin Jr.
post #9 of 11 Old 03-01-2012, 05:09 PM
Jason
Good post, but the pics are huge!
And that's a very nice IH, btw.
Jason is offline
post #10 of 11 Old 03-01-2012, 05:14 PM Thread Starter
AMCMasterTech
Sorry bout the pic size....I couldn't edit them any smaller.
Roy D. Chapin Jr.
post #11 of 11 Old 03-01-2012, 05:34 PM Thread Starter
AMCMasterTech
Thanks for the compliment. That truck could've just as easily been a J-20, and very nearly was. But I was off-shore at the time and someone else beat me to the Jeep pickup. However, like so many CL deals, the 200 fell in my lap, right place right time. IH made some excellent light line vehicles; very glad to have this one!
Roy D. Chapin Jr.
Broken bolts needing removal. Shoelessboi General Jeep & Off-Road Equipment 6 02-18-2012 09:11 PM
Broken Thermostat Bolt uytterhagen Engines & Drivetrain 0 08-02-2011 07:46 PM
Broken bolt extraction? harley2003rkc Engines & Drivetrain 4 09-26-2008 07:44 PM
pinion nut and broken yoke strap bolt Peccavi18 Engines & Drivetrain 2 06-13-2006 08:17 PM
Broken Bolt Blues cj-7 kid Fabrication Shop 4 01-20-2004 07:51 AM
