Broke a ring gear bolt!?! - JeepForum.com
post #1 of 11 Old 10-10-2013, 10:11 PM Thread Starter
365Jeep
Okay, I was installing my new ring gear tonight when one of the bolts broke! I was tightening them in a crossing pattern, first at 20 ft-lbs, then 50, then 80 to finish and... SNAP! Now what? Do I have to start over with new bolts? The FSM says 70-90 ft-lbs.
365Jeep is offline
post #2 of 11 Old 10-11-2013, 08:26 AM
Evildriver-3
What diff, no jeep diff (Dana) see's 80 on RG bolts.
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 11 Old 10-11-2013, 12:19 PM Thread Starter
365Jeep
Apparently, but the Factory Service Manual says 70-90.
365Jeep is offline
post #4 of 11 Old 10-11-2013, 12:25 PM
Duh
When a bolt is tightened into its yield zone it needs to be replaced if removed. Anything with a torque+ degree is always that way. Some with a simple torque number are too. Anything thats load/torque bearing i always replace.
Duh is offline
post #5 of 11 Old 10-11-2013, 12:39 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
There are conflicting torque values for ring gear bolts, likely due to the bolt size change from 3/8" to 7/16".
What size ring gear bolts are you dealing with?
Wheelin98TJ is offline
post #6 of 11 Old 10-11-2013, 02:23 PM
Evildriver-3
What diff is this, I didn't need to know the manual is wrong, I know already, forget it, 55 lbs D25 thru 44
]=Supershafts=[
post #7 of 11 Old 10-11-2013, 02:53 PM Thread Starter
365Jeep
It's a reverse cut D30. I think my local O'Reilly Auto Parts carries individual bolts. I can do 55 lbs. That will be a lot less stressful. 80 ft-lbs seemed really tight. Thanks.
365Jeep is offline
post #8 of 11 Old 10-11-2013, 03:12 PM
Wheelin98TJ
JEEP FREAK
Someone was smoking weed when they wrote the Jeep FSMs saying torque a 3/8" bolt to 70-90 ft/lbs.
post #9 of 11 Old 10-12-2013, 11:24 AM
GilaMtnJeep
GilaMtnJeep's Avatar
If you broke one and torqued all of them that tight, replace them all. Bolts are not expensive and you know everything will be ok after you close it up.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #10 of 11 Old 10-12-2013, 07:48 PM
0125JeepGuy
i would drill it out and replace it with hardened bolts. or whatever tickles your fancy. when i bought my gladiator, the previous owner replaced the ring and pinion and broke a couple bolts and left it like that. come to find out, after going thru the diff, it was trashed (maybe because of this, but who knows why) i mean there were chunks missing in the pinion, the casing had a crack in it the spider gears were all screwed up and the cover had dings in it from the inside from the ring hitting it (why i dont know) but if i were you i'd play it safe
0125JeepGuy is offline
post #11 of 11 Old 10-14-2013, 11:16 PM
gearswapper
I agree with Whitemtnjeep, carefully remove them and install a new set torqued to 55. I also use red threadlocker on all of the ring bolts I install for customers. Its cheap insurance.
gearswapper is offline
