Brake replacement, brakes now locked - JeepForum.com
post #1 of 3 Old 05-19-2012, 05:45 PM Thread Starter
MrBlah
So, today was time to replace my brakes on my 97 TJ. New rotors, new pads. Well, after putting everything back together, the rotors were locked. So I took it back apart. I was able to freely spin the hub with the new rotors and pads in. Put a wheel back on a hub and tightened it, wheel was locked after spinning it less than one revolution.
What am I missing?
MrBlah is offline
post #2 of 3 Old 05-19-2012, 06:07 PM Thread Starter
MrBlah
Never mind! I found the problem, going to TJ forum.
MrBlah is offline
post #3 of 3 Old 05-19-2012, 06:17 PM
aw12345
You got the wrong rotors. 97's used a stamped rotor, instead of a cast one.
Forgot the correct name for it, but that is what's wrong
aw12345 is offline
1996 Jeep Cherokee 4WD- Brake Issue. Master Cylinder? Bleed Brakes? Busted Brake Line mjkjr1222 General Jeep & Off-Road Equipment 0 08-06-2011 09:25 AM
Bad replacement brake master cylinder? cargovoyage Engines & Drivetrain 0 07-20-2011 08:59 AM
Need help with brake replacement! Tmblack3 General Jeep & Off-Road Equipment 24 05-06-2011 11:35 AM
something strange happened to my e-brakes / parking brake... 0okamiDigital General Jeep & Off-Road Equipment 2 04-26-2011 07:37 PM
99 cherokee front brakes locked? SPK Cheap Tricks & Fixes 2 05-23-2010 12:01 PM
