brake problem - JeepForum.com
post #1 of 5 Old 03-27-2006, 08:05 PM Thread Starter
JOKER4INK
brake problem
I needed brakes on a XJ, so I replaced the front calipers & rotors, pads, a new master cylinder and new power brake booster. Since then, I have a ton of air the front brakes. I get decent brake pressure when the motor is off, but as soon as I start it the pedal goes to the floor. I used a one-man bleeder and then tried it the old fashioned way when someone pumps the pedal while I do the bleeder screws. Either way I have no brake pressure. I am at a loss right now. There is a ton of tiny air bubbles coming out of the lines and there is a ton coming out of the reservoir too. There is no brake fluid leaks. What do I do? Does the system need to be pressure bled?
88 YJ...kinda. Clayton Hard Arms, V8, 1 tons running gear, twin sticked, Irok's, fuel cell, multi-colored
JOKER4INK is offline
post #2 of 5 Old 03-27-2006, 09:02 PM
WVBLACKJEEP
WVBLACKJEEP's Avatar
Did you bench bleed the master cylinder before you installed it?
WVBLACKJEEP is offline
post #3 of 5 Old 03-27-2006, 09:47 PM Thread Starter
JOKER4INK
I never bled one before, so this is what I did: I filled the reservoirs, put the fittings and hoses on the ports, ran the lines back into the reservoir. Pumped the acuator a few times til no air bubbles were present. took the hoses and fittings off, hooked up the brake lines and attempted bleeding the brakes at the calipers. Is that right? Do I need to hold the plunger for the master cylinder in while I hook up the lines or something? what did I do wrong?
post #4 of 5 Old 03-27-2006, 10:15 PM
WVBLACKJEEP
If you had no air bubbles in the master cylinder during your bench bleed your master cylinder should be primed and ready to go. Now move down to the ft. calipers and try a rebleed on those again.
Just a question did you attempt to bleed the rear cylinders?
They may have gotten air in them also.
post #5 of 5 Old 03-27-2006, 10:26 PM Thread Starter
JOKER4INK
I did bleed one rear. The other had a broken bleeder. The one I bled had very very little air.
Brake caliper problem with HP dana 44 front heinie_21 Fabrication Shop 4 06-10-2009 01:56 PM
LED 3rd Brake Light Problem Jebussaves0 Audio, CB & Ham Radios, GPS, & Electrical 4 06-07-2009 11:33 AM
Crazy Brake Light Problem AlmoStok Audio, CB & Ham Radios, GPS, & Electrical 2 04-24-2009 06:10 PM
Rear turn signal/brake problem hsif Audio, CB & Ham Radios, GPS, & Electrical 2 06-09-2007 12:40 AM
