Blue Smoke - JeepForum.com
post #1 of 8 Old 10-12-2013, 07:38 PM Thread Starter
0125JeepGuy
Blue Smoke
in my '69 buick 350 in my gladiator, i have true dual exuast and she doesnt get ran much at all (only went down the road a few miles once this year). when i went and started it up a few days ago, the drivers side began smoking blue smoke especially when i revved it alittle. what my dilemma is, is that the engine was completely rebuilt around 3,000 miles ago so it wouldnt make sense for the valve seals to be bad already or even for the piston rings to be worn out. i know blue means oil so im just not sure.
0125JeepGuy is offline
post #2 of 8 Old 10-12-2013, 08:58 PM
uberxj92
1992 XJ Cherokee
How long sitting with that new motor? 3000 isn't broke in yet. If a new engine sits too long the seals will dry out fast. Doubt its the rings. Did you use zinc additive on first 1000?
True duals are nit that good for an engine especially fresh ones. Need an H pipe in it to equalize the engine.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 8 Old 10-13-2013, 07:25 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Go drive it and get it up to temp.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 8 Old 10-14-2013, 06:48 PM Thread Starter
0125JeepGuy
Originally Posted by uberxj92
How long sitting with that new motor? 3000 isn't broke in yet. If a new engine sits too long the seals will dry out fast. Doubt its the rings. Did you use zinc additive on first 1000? True duals are nit that good for an engine especially fresh ones. Need an H pipe in it to equalize the engine.
i really dont know how long its been because when i bought it, thats how many miles it had and i dont know when he rebuilt the engine but i've only put about 50 miles on it since i bought it (july 2012). i dont know if he put zinc additive in it either. but thank you for the info i appreciate it
post #5 of 8 Old 10-14-2013, 07:53 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Agreed! Get some miles on this engine.
One question. Have you changed the oil yet? It should have been started with break in oil and then it and the filter changed out after about 500 miles.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #6 of 8 Old 10-16-2013, 07:06 PM Thread Starter
0125JeepGuy
Originally Posted by laybackman
Agreed! Get some miles on this engine. One question. Have you changed the oil yet? It should have been started with break in oil and then it and the filter changed out after about 500 miles.
not since i bought it i havent changed it. and i bought it with 3000 miles on it so i dont know when the filter has been changed either
post #7 of 8 Old 10-16-2013, 07:25 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
I think it should get a new filter on it and some 10w-30 oil ASAP.
post #8 of 8 Old 10-16-2013, 07:37 PM
uberxj92
1992 XJ Cherokee
No additives!!
uberxj92 is offline
