Bloody Forhead ('94 ZJ 5.2L running rough) - JeepForum.com
post #1 of 5 Old 11-01-2008, 08:22 PM Thread Starter
ScottN3N
My forhead is bloody from banging it against the wall. Any help is appreciated. I have a 94 Grand Cherokee, 5.2L all time 4wd. Starts & idles fine. Runs VERY rough above idle. Won't go over 20-30 mph & did I mention ROUGH. After it warms up for 15 min or so it will run just fine - plenty of power, smooth. Like something comes up to temp & decides to work properly. I've done the following with no luck. New plugs, wires, coil, cap & rotor. New MAP sensor. Removed & cleaned all injectors (soaked in B-12) new O rings. New fuel pump & filter. Fuel pres. in spec. Compression good. Run several cans of B-12 through it. Plugged Idle AIr Control valve - (all that did was make it idle poorly). I thought maybe it was stuck open. Can't find a vacuum leak. Codes are 14 - Map sensor voltage (has a new MAP sensor) 27 - injector control output drivers. All injectors seem to work. 54 - no camshaft position sensor signal from distributor. (can that be affected by operating temp?) What has me realy puzzled is that it will run fine after it warms up for 15 minutes or so (thoroughly warmed up). I've not changed the O2 sensor - yet - but I don't think that would have this much affect. Thanks for your time & help.
ScottN3N is offline
post #2 of 5 Old 11-02-2008, 12:30 AM
bjf498
bjf498's Avatar
1983 CJ7
Have you checked the temp sensor?
Small, fine shavings are ok, large chunks are bad, huge chunks with part number stamped on them are real bad.
bjf498 is offline
post #3 of 5 Old 11-02-2008, 01:37 AM
willness33
Good thought, however I think it's working properly since it runs poor in open loop "cold operation mode" and runs fine when warmed up. I think it is seeing the temp differential. The TPS would be another thought, and only because it's one of the few sensors that the ECU pays attention to in open loop. Honestly, this is where I'd spend the next dollars.
See above explanation. The o2 sensors don't come into the mix regarding the ECU and engine management until the engine is up to temp. Since you say it runs fine when warmed up tells me the o2 sensors are ok.
Now the one thing that has me a bit cornfused is why would a bad TPS cause these problems in open loop and not closed? Input from the TPS is still used in closed loop "warm mode", but it's integrated with the feedback from the o2sensors at the same time. Headscratcher for sure. Since you've thrown every part at the whole thing but the temp sensor, TPS and o2 sensors and are likely to throw more parts at it, I'd still suggest a new TPS. At least, that's what I'd do. Take it for what it's worth.
willness33 is offline
post #4 of 5 Old 11-02-2008, 09:28 AM Thread Starter
ScottN3N
I'll give the TPS a shot. Thanks.
ScottN3N is offline
post #5 of 5 Old 05-19-2012, 08:36 AM
vol96
So was it the tps? Is only been 3 1/2 years. I'm sure you still have the jeep and can report the solution :-)
vol96 is offline
old cj 258 running rough sparctacus Engines & Drivetrain 4 02-19-2010 03:25 PM
Weber carb running rough! (know someone?) ecartaya Engines & Drivetrain 0 01-21-2010 05:44 PM
85 XJ 2.5 tbi running rough need ideas. TwistedEvo8 Engines & Drivetrain 0 02-18-2009 03:43 PM
Running Rough / Popping noise dunvillekid Engines & Drivetrain 0 06-08-2007 02:25 AM
87 2.5 running rough 79cherokee Engines & Drivetrain 1 07-16-2006 10:31 PM
