Bi-Fuel TJ, 200-proof Ethanol/Gas - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Bi-Fuel TJ, 200-proof Ethanol/Gas
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6
Unread 04-30-2006, 04:13 PM   #1
Rockiholic
I've been working on designing a bi-fuel System for my 2.5 TJ. Basically I was thinking about making an entire fuel system for the alcohol that merges with the gasoline at a 'T' Valve to switch between the fuels, just before the injectors. I figure that injectors that are 40% bigger should work(not sure what would work, suggestions?) . I was thinking about some Champion RC14 spark plugs for the alcohol. Because the alcohol burns slower I think I need some ingnition advancement (20 degrees?), is there an aftermarket chip that can re-time ignition, or is a shop the best bet? I'm still kicking around a few ideas, but a write-up will follow. FYI- the gas part is basically used to warm up the engine, with the 200-proof ethanol handling the majority of the work. Thanks for the help.
Rockiholic is offline   Reply With Quote
Unread 05-01-2006, 08:11 AM   #2
75SV1
Might look here:
http://e85vehicles.com/e85/index.php...171a&board=5.0
Also, might search some alternative energy sites or free energy sites.
Tom
75SV1 is offline   Reply With Quote
Unread 05-02-2006, 05:17 AM   #3
75SV1
Look at this thread:
http://theoildrop.server101.com/ubb/...;f=46;t=000090
The links in the post look interesting. Just do some more research. Fuel lines and compatability. The FuelFlex system looks interesting and not that expensive.
Tom
Unread 05-02-2006, 02:58 PM   #4
tjsooley
http://xcelplus.com/E85/e85informationcenter.htm
this place telles you what you need to do to make your vehical flex fule
[COLOR="Red"]______
l ,[____],
l---L –0lllllll0-
()_) ()_)--o-)_) [/COLOR]
[url]http://www.myjeepspace.com/profile.php?id=653[/url]
tjsooley is offline   Reply With Quote
