Best/easiest small block swap - JeepForum.com
post #1 of 22 Old 09-04-2013, 08:17 PM Thread Starter
jeepster02
At some point, I want to do a small block swap in my YJ. It currently has a rebuilt 2.5l. It wont let me upload pics from my phone or I would post rebuild pics. I would prefer to go fuel injected, but open for other options.
jeepster02 is offline
post #2 of 22 Old 09-04-2013, 11:06 PM
uberxj92
1992 XJ Cherokee
Just sold a cj with an lt1. Only kept it for 2 months after the swap. I just didn't like it. Felt wrong MPG sucked and had to spend more time and cash on fuel cell. The stock tank and lines were no where near good enough.
I would suggest an inline 6. Either the 4.2 or 4.0. The 4.0 would be great with efi and stroke it.
If its speed you want then you could hear it better. Just a thought
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 22 Old 09-04-2013, 11:42 PM Thread Starter
jeepster02
Correct me if I am wrong, but I thought maybe the mpg wouldnt change much. This is why, the 4cyl has to work harder and only gets like 17 mpg. So, I figure, not having to work as hard, the mpg for the small block wouldnt be much different, if not a little better. The mpg really isnt too big of a deal, because the furthest we drive it is about an hour away and thats only to go the river. Id be totally fine with an inline 6. I would just have to find one cheap.
post #4 of 22 Old 09-05-2013, 09:56 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Just figure that everything you do to a Jeep will make the mileage worse. Get past that crap and stick with the desire to get more power. I went with a 4.3V6 from a 2.5L, and with the 4.88 gears I've never had power issues on or off road.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #5 of 22 Old 09-05-2013, 10:23 AM Thread Starter
jeepster02
Ok then, inline 6 it is. Now I would assume a donor Jeep or scrap yard would be a good place to start. I am not too familiar with engine swaps, so what all would I need. T-case, tranny, etc.
post #6 of 22 Old 09-05-2013, 09:09 PM
uberxj92
1992 XJ Cherokee
Lots of Google info and threads on swaps. You first need to decide Carb or efi. Efi is the best way to go then you'll want the 4.0.
You'll need the engine harness or make one, the ecu, sensors.
If you go automatic Tranny you'll need the linkage and tcu.
uberxj92 is offline
post #7 of 22 Old 09-05-2013, 10:57 PM Thread Starter
jeepster02
I would much prefer manual tranny and efi, but it all comes down to what I can find when I have the funds.
post #8 of 22 Old 09-06-2013, 04:54 AM
uberxj92
1992 XJ Cherokee
What year is your rig? Stick or auto? I ask cause it will help us give you advice on the easiest swap
uberxj92 is offline
post #9 of 22 Old 09-06-2013, 08:13 AM Thread Starter
jeepster02
I have a 94 yj with a manaul tranny.
post #10 of 22 Old 09-06-2013, 08:43 AM
rjbruzan
Easiest is a Carbed Stick shift.
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #11 of 22 Old 09-06-2013, 10:26 AM Thread Starter
jeepster02
Ok, so carb would be easiest, but I think I would just rather have efi. It cuts down on having fuel issues IMO. I assume the 4.0 would be the route then. So, the next question is and might be a dumb one, but would I need the tranny/t case for the 4.0 as well or would mine work?
post #12 of 22 Old 09-06-2013, 11:30 AM
rjbruzan
Yes. Get a whole 91-95 Cherokee as a donner vehicle.
rjbruzan is offline
post #13 of 22 Old 09-06-2013, 12:50 PM Thread Starter
jeepster02
Ok, well I guess when I have the funds, I will work on getting the parts. Thanks for all the info fellas.
post #14 of 22 Old 09-06-2013, 12:58 PM
uberxj92
1992 XJ Cherokee
94's had 4.0's too. Most of the mounts should work.
Look for ax15 Tranny easy swap with yours
uberxj92 is offline
post #15 of 22 Old 09-06-2013, 01:13 PM Thread Starter
jeepster02
Ok, thanks alot. I am sure I will have more questions once I have the stuff.
