Belt squeals when start, then goes away??? - JeepForum.com
post #1 of 4 Old 01-03-2013, 08:17 AM Thread Starter
joekachman
Every time I start my cherokee the belt squeals for about a minute then goes away. Could it be the bearings in one of the pullys or a bad belt?
joekachman is offline
post #2 of 4 Old 01-03-2013, 12:11 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Tighten the belt.
Next....
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #3 of 4 Old 01-03-2013, 07:58 PM
jokerchief462
Replace the belt and while it is off inspect the pulley for foreign matter oil, grit, rust etc. If is a serpentine check the idlers for bad bearings. If it is a V belt same procedure.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 4 Old 01-03-2013, 08:12 PM
leftlanetruckin
XJ on 37's
XJ should be a manual tensioner IIRC, thus my tighten the belt comment....
Martin
