Before I Start, how hard is it? - JeepForum.com
post #1 of 10 Old 01-18-2014, 04:54 PM Thread Starter
2tall2slow
I have a sneaky suspicion that my fuel pump is going bad. What are the tell tale signs of this? And before I attempt to replace myself, how hard is it? 94 Cherokee.
2tall2slow is offline
post #2 of 10 Old 01-19-2014, 05:32 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Why are you suspicious that your fuel pump going bad? Symptoms?
First thing you have to ask is when did the inline fuel filer get changed? Don't know? Then it is time to do that before you go dropping the gas tank and swapping out the fuel pump. At least that is what I would do.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #3 of 10 Old 01-20-2014, 02:39 AM Thread Starter
2tall2slow
I am changing filter this afternoon 1st, before i do anything expensive. It was last changed approx 3-4 years ago. Jeep sputters and kicks randomly like it isnt getting enough gas. Used some really good injector cleaner that shouldve wofked but didnt, thats leading me to filter/pump.
post #4 of 10 Old 01-20-2014, 05:55 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
Another cheap fix is to remove the Throttle Position Sensor and clean it AND the bore it sits in with 0000 steel wool and carb cleaner. Do not pull the end of the TPS out of it's body or you have to buy another one.
I would also test fuel pressure at the fuel rail.
Or, it might be a fuel pressure regulator problem.
You are assuming that the problem is fuel.
I would throw a timing light on this engine and see what the timing does when you increase the RPMS. That is when it is running poorly. A stretched timing chain could be the problem.
post #5 of 10 Old 01-20-2014, 06:16 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I think you meant Idle air Controller? Not TPS?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #6 of 10 Old 01-20-2014, 06:21 AM
laybackman
laybackman's Avatar
2010 JK Wrangler
GOOD CATCH!!!!! IAC not TPS
Gotta get some coffee into me before typing.
post #7 of 10 Old 01-20-2014, 06:32 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I know all about that!!
post #8 of 10 Old 01-20-2014, 04:01 PM Thread Starter
2tall2slow
I am assuming that the problem is fuel. Just took the dreaded gasoline bath changing my filter. Hope that'll do it because I have no idea how to check my fuel pressure regulator or test for pressure at the rail. Let it be known, my tool box consists of some sockets, wrenches, and a DMM. A handy go-to. BTW. Idle air controller is what exactly?
post #9 of 10 Old 01-20-2014, 04:08 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
http://www.cherokeeforum.com/f51/tbi...eaning-179079/
post #10 of 10 Old 01-21-2014, 07:50 AM Thread Starter
2tall2slow
Filter didn't seem to be the problem. Very good, detailed information and seemingly easy inexpensive tips to troubleshooting there cruiser. This will be my reference today.
