Bare Essentials - JeepForum.com
post #1 of 5 Old 10-15-2007, 01:26 PM Thread Starter
dryfire1
Bare Essentials
I have a 1988 jeep wrangler with a 4.2 L motor straight 6.
What would happen if i plug the tube that runs from the Exhaust maifold to the intake manifold. I believe its called a EGR tube.
Also there is a tube that runs from the exhaust manifold to the other side of the motor. ( pulse air upstream).
Any one tried that?
dryfire1 is offline
post #2 of 5 Old 10-18-2007, 08:04 PM
jay-h
Plugging them will do little for performance. The EGR can actually make it run a bit better, because it moderates combustion temperature.
As for the exhaust pulse streams, the engine will run about the same with or without.
jay-h is offline
post #3 of 5 Old 10-18-2007, 09:07 PM
xxxflhrci
xxxflhrci's Avatar
I took all of it off of mine when I did the Weber.
xxxflhrci is offline
post #4 of 5 Old 10-19-2007, 11:11 AM Thread Starter
dryfire1
The Pulse air stuff im removing.
That seemed to remove some of the vacum leaks.
What all do you have hooked up with the Weber carbs.
Can i remove all the hoses going to the vacum canisters also?
dryfire1 is offline
post #5 of 5 Old 10-19-2007, 11:50 AM Thread Starter
dryfire1
Can i remove this tube. from
dryfire1 is offline
Trail essentials... tools, parts, etc.. NotMatt General Jeep & Off-Road Equipment 26 12-06-2009 12:37 PM
Essentials for 4x4 trip...Utility tool that fixes everything? freeunit General Jeep & Off-Road Equipment 31 05-29-2009 10:55 AM
bare metal rusting GPEWETT General Jeep & Off-Road Equipment 5 08-11-2008 08:45 PM
Bare Steel MDC3 General Jeep & Off-Road Equipment 3 10-07-2006 08:06 PM
Jeep Essentials SYE zbrucec Engines & Drivetrain 11 05-28-2006 03:33 PM
