Ball joint replacement fun - JeepForum.com
post #1 of 7 Old 11-07-2012, 11:08 PM Thread Starter
Shadowdog500
Videos of my ball joint remove and install
Videos of removal and install below.
I bought a OTC 8031 jeep/truck balljoint kit to replace the balljoints on my 03 grand cherokee. the balljoints came out with ease but I hit a brick wall when installing the bottom one. The cup to install the lower balljoint is too short and the half inch or so of metal below the threaded part of the balljoint is bottoming out about 1/8 " before the top of the cup can get to the driving surface. There isn't a longer cup in the kit so i either have to buy, or make a longer one, or I'm going to cut the metal below the threaded part of the balljoint as a last resort. I'll star looking for a longer cup tomorrow. I'm recording the job so hopefully a video will come out of this.
Chris
Shadowdog500 is offline
post #2 of 7 Old 11-07-2012, 11:13 PM
Ripper3494
pictures would aid in advice. i failed to follow you a little
build thread:
1997 ZJ limited - BONE stock
RC vs BDS
Ripper3494 is offline
post #3 of 7 Old 11-08-2012, 10:27 AM
rjbruzan
As a last ditch resort Harbor Freight has a spacer kit for around 50 bucks.
I often use rigid water/gas pipe nipples or couplings from the hardware store to make adapters.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #4 of 7 Old 11-08-2012, 11:53 AM Thread Starter
Shadowdog500
Yeah, I wrote that at like 1 am when I was bleary eyed and came back in the house from my shop. I probably wasn't making much sense. I will post a few photos tonight. I came up with the solution today. I had a piece of schedule 80 pipe that fit the lower balljoint perfectly and will fit onto one of the driving cones for the press. Trimmed it to the right size on the lathe and am now set. Hopefully I will get the balljoints in tonight and will have a youtube video posted.
Chris
post #5 of 7 Old 11-09-2012, 07:10 AM Thread Starter
Shadowdog500
Here is a video of the balljoint removal.
I plan to go out and install the new ones today.
Chris
post #6 of 7 Old 11-11-2012, 05:20 PM
RedlegWJ
I bought a ball joint install kit from harbor freight this summer. Just did my uppers the other day. The HF kit was just barely useable. I haven't tried it on the lowers yet. If I had to do it again, Is just get the kit from advance or autozone. Worked good last time.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #7 of 7 Old 11-22-2012, 11:32 PM Thread Starter
Shadowdog500
Here is the video of the ball joint install.
Chris
