bad wheel bearing? please help! - JeepForum.com
post #1 of 3 Old 10-17-2013, 10:19 AM Thread Starter
wk07laredo
While driving at freeway speed I felt a rapid vibration start in my rear end. I pulled over and the right rear wheel had a burning oil smell coming from it. I got back on the road and it was gone. This has happened 3 times over the last month or two.
Thoughts?
2007 grand Cherokee 4.7l flex fuel. 4x4.
wk07laredo is offline
post #2 of 3 Old 10-17-2013, 11:32 AM
Evildriver-3
I would check that, it could be many different things, better get that on a lift or jack stands and see whats going before it costs you way more.
Just so you know , ANY vibration is VERY bad, it means something is WAY out of spec and most specs are .000 tolerances so when you CAN FEEL it, it's costing you more
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #3 of 3 Old 10-18-2013, 09:04 AM
0125JeepGuy
Originally Posted by Evildriver-3
I would check that, it could be many different things, better get that on a lift or jack stands and see whats going before it costs you way more. Just so you know , ANY vibration is VERY bad, it means something is WAY out of spec and most specs are .000 tolerances so when you CAN FEEL it, it's costing you more
this is true, my rear dana44 was vibrating so bad after i started getting into the axle it was so bad i just replaced the whole thing
0125JeepGuy is offline
