Bad vibrations in England - JeepForum.com
post #1 of 6 Old 03-29-2012, 01:34 PM Thread Starter
Slasher
2006 KJ Liberty
Hello all, long time lurker but new member. Its my first post so please be gentle.
I have a problem that I cant find any answers to and it's to do with vibration.
The problem - Monday night I was driving and when I hit 40 mph, the car started to vibrate and will kept vibrating until virtually stopped. I thought Torque Converter (had one go on a C Class Mercedes last year and thats why I bought the Jeep). Tuesday afternoon I took it to a local Auto Gearbox (transmission) repairer who took it for a test drive and heard/felt it but it kept vibrating in neutral so they said to leave it with them Wednesday so they can put it on a lift and check it all in the workshop. When I went to pick it up they said they don't think its the Torque Converter just my Transfer Case is a bit noisy.
Anyone have any ideas what it could be? 40 mph = vibration in drive and 2nd gear (don't know if it was clever to try that one) 2WD and 4WD same in neutral, with O/D on or off and same if turning or straight.
I've got it booked into a good independent garage in the morning to check it over but not too sure what I need to tell them to check.
Sorry for a long first post but any help/tips/ideas greatly appreciated.
Jim
Slasher is offline
post #2 of 6 Old 03-29-2012, 03:43 PM
dillonreid
1992 XJ Cherokee
Did they look at any mounts? I don't know much about them myself just got mine but I've had them go in a civic and it was pretty rough as well
http://www.jeepforum.com/forum/f22/my-jeep-geoff-texas-build-1348154/
dillonreid is offline
post #3 of 6 Old 03-30-2012, 10:45 AM Thread Starter
Slasher
2006 KJ Liberty
Thanks Dillon, quick update, bushes on the rear 'A' frame gone, they could move the near side (or drivers side for those on the other side of the pond) one about half an inch backwards and forwards I dont know it both sides are supposed to be the same but they're not, looks like one is upside down (and shot). Mechanic thinks thats the problem as its letting the axle flex and thats whats probably causing the vibration through the propshaft and then through the car.
Part on order should be fixed Thursday.
Does this sound right, anyone else had this happen?
Thanks again.
Slasher is offline
post #4 of 6 Old 03-30-2012, 01:13 PM
dillonreid
1992 XJ Cherokee
That definitely sounds like it would cause that good luck
post #5 of 6 Old 04-07-2012, 01:46 AM Thread Starter
Slasher
2006 KJ Liberty
Update
Boomerang changed, doesnt seem to wallow around as much now BUT the vibrations still there, nowhere near as bad as it was though. So I've decided I'm going to change the U Joint, 2 garages have said they checked them and said they are fine but one of them also passed an M.O.T. in Jan and 3 bushes dont go that quick
After looking on here and other places it seems its an easy part to get until you start double checking, aparently its a Spicer 1310 (rear u joint at axle) but I've also got 8 other part numbers depending on manufacturer .
Anyway it's going to have to wait and hopefully last another couple of hundred miles as I'm off to see Hadrians Wall and the first Hogwarts on Monday I'll let you know if it makes it!
Slasher is offline
post #6 of 6 Old 04-07-2012, 11:36 AM
dillonreid
1992 XJ Cherokee
Well sounds like you are getting it figured out lol
need led options...moving to england snow0806 Audio, CB & Ham Radios, GPS, & Electrical 1 01-22-2010 11:01 AM
Camping places in New England? Zombi General Jeep & Off-Road Equipment 7 04-04-2009 01:39 PM
New England Fab Shop vtjeeps Fabrication Shop 2 01-14-2007 10:52 AM
New England Area or advice Jeepaudi Fabrication Shop 3 09-26-2003 09:55 PM
Looking for a transmission in New England katiedog Engines & Drivetrain 1 06-23-2002 08:33 PM
