bad lifter? - JeepForum.com
post #1 of 6 Old 11-19-2013, 04:20 PM Thread Starter
bumperthumper
bad lifter?
Alright so I just picked up this ZJ, and it wasn't firing on a cylinder. Valve cover off told me that a pushrod got stuck in the rocker. All new pushrods and rockers, and when I go to put the problem cylinder on, the pushrod comes up short. I'm guessing the lifter is collapsed, but I figured I'd put it out there and see if anyone else has something to say. So, bad lifter?
bumperthumper is offline
post #2 of 6 Old 11-19-2013, 04:33 PM Thread Starter
bumperthumper
pics
post #3 of 6 Old 11-20-2013, 06:23 AM
lsuguy4
What kind of noise did you have? Knocking or ticking around in the motor?
lsuguy4 is offline
post #4 of 6 Old 11-20-2013, 09:18 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Either the push rod shrunk or the lifter did!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 6 Old 11-21-2013, 07:59 AM
BIGBADWOLF
Even if the lifter collapsed it would be less than 3/16 of an inch. What is your valve spring height? Does the lash get less when you turn the engine over? Is rocker fulcrum nut tight? If all that checks out your looking at a worn cam lobe or severely worn lifter.
What cylinder? Do you lose coolant?
BIGBADWOLF is offline
post #6 of 6 Old 11-21-2013, 08:05 AM
BIGBADWOLF
Never mind.....I missed the picture in your 2nd post
